Bad sound when engine starts [SOLVED]
- futureZ4buyer
This only happens when the engine is cold and not driven for at least a day.
I'm charging the battery to see if it is the reason why this is happening.
Will check tomorrow.
Any other suggestions?
PS if you can't hear it well, put your headphones on.
https://youtu.be/xTj8ng32a00
Last edited by futureZ4buyer on Sat Sep 04, 2021 12:20 pm, edited 1 time in total.
E85 2.2i
There will be far more technical people than me on here but sounds like a starter motor to me...
Wait for proper advice from someone else tho
Onlinebigwinn
If that’s the consensus I’m changing mine today
I’ll do a write up how it goes
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- maxman
Sounds like the starter ,could be caused by a low battery.
- colb
Very difficult to make the sound out even with headphones but may detect the bendix being slow to retract once the car starts and it spins the starter motor a bit before retracting like it should. Pull it out and give it a clean and light lube so it slides freely and then give it a try, you can bench thest it with 12v put to it. These starters give no warning of failing had to change mine recently.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
- futureZ4buyer
Thank you for answers gentlemen!
Battery was fully charged this morning and it happened anyway so it's probably the starter.
Will do what @colb suggested.
E85 2.2i
Onlinebigwinn
starter changed bud- will do a write up in a few mins for you in the 'how to' section
EWS Delete PM me
EWS Delete PM me
Or give it a tap with a hammer and block of wood in the short term, see if that sorts it out...
- futureZ4buyer
- Roberltd2
Engine sounds nice though
2007 E85 2.5 si Sport in Montego Blue.
1994 Eunos J2Ltd - sold and now undergoing restoration.
1963 Triumph Thunderbird.
- Rockhopper
It’s not a bendix style starter on the Z4, it’s a pre engaged one where the solenoid moved the starter gear into mesh with the ring gear before then turning the engine over. Might be worth knowing if you are looking for a replacement.
- futureZ4buyer
It does, I'm happy with it
Thanks! Everything will be checked when the spring arrives. Until then it will be in a garage because the weather is and will be s**t.Rockhopper wrote: ↑Mon Dec 28, 2020 9:23 am It’s not a bendix style starter on the Z4, it’s a pre engaged one where the solenoid moved the starter gear into mesh with the ring gear before then turning the engine over. Might be worth knowing if you are looking for a replacement.
E85 2.2i
- futureZ4buyer
Solved about 3 months ago!
Starter motor was causing this sound.
It was refurbed and the sound is gone.
E85 2.2i
