E85 / E86 Water Deflector fixings
- samuir1974
Hi folks,
Popped the bonnet on the Z4 2006 to do some winter maintenance today.
Found this loose plastic piece which i'd never come across before.....
Seems to be the Water Deflector for the HVAC intake and attached to the underside of the bonnet. Item #1 (bmw 64116924539)
Just need to get the fixings ordered - the old ones appear lost and gone? Anyone had the issue and got the part number for the fixings or a better fix?
Thanks in advance.
Ste.
Thanks in advance.
Ste.
Current - 2007 BMW Z4 3.0 Si Auto
Gone - 2017 Audi RS7 Performance
Gone - 2006 BMW Z4 2.5Si Sport
Gone - 2018 VW Golf .:R
Gone - 2010 BMW Z4 35iS
Gone - 2009 VW Passat .:R36
- enuff_zed
Item 5? - 51711958025
If that's the Realoem picture then the list should be directly below it?
- samuir1974
Thanks - found the picture elsewhere in the first instance.... now located it on realoem as you say.
Item #5 is shown but not sure if i need 7 as well - its unclear to me on the mechanism - seeing as no existing fittings survived
Plus - interested if anyone has an improved fix.
Cheers,
Ste.
- enuff_zed
Wife is out in the car, so can't check, but I think Item 7 is to hold the big drain tube in place.samuir1974 wrote: ↑Wed Nov 25, 2020 3:51 pmThanks - found the picture elsewhere in the first instance.... now located it on realoem as you say.
Cheers,
Ste.
Looking at the diagram, I would expect to see four corresponding studs on the car bodywork that the Item 5 nuts fit on to.
- samuir1974
Indeed buddy - that's my issue exactly; the underside of the bonnet only has 4 holes - not studs.
Hence why the diagram isnt quite making sense for this one...
Appreciate if you can check or share an image when you get access.... thanks.
- enuff_zed
Wifey only just got home, it's dark and pi$$ing down!samuir1974 wrote: ↑Wed Nov 25, 2020 5:06 pmIndeed buddy - that's my issue exactly; the underside of the bonnet only has 4 holes - not studs.
Send me a reminder in the morning
- samuir1974
Any joy with some images buddy? Still no further forward on this - thanks
- enuff_zed
Completely forgot, sorry.samuir1974 wrote: ↑Sat Nov 28, 2020 1:28 pmAny joy with some images buddy? Still no further forward on this - thanks
Just got them now.
Assuming you mean the hard plastic bit under the passenger side of the bonnet?
Mine seems to be fitted with the plastic rivets, more like Item 7 in the picture.
- samuir1974
Thanks for the images buddy - and confirming my suspicions....
The tech diagram showing item #5 seems totally wrong.
I did order item #7 on that basis but at approx 4mm width - the rivets seem a little too small.
Going to try get hold of a 5mm version and re-check the fitment.
Thanks again for taking the time to post the images
- enuff_zed
No problem. sorry it took so long.samuir1974 wrote: ↑Sun Nov 29, 2020 12:19 pm Thanks for the images buddy - and confirming my suspicions....
If originality wasn't an issue you could maybe pop-rivet it on, but my concern would be the extra gripping pressure cracking the plastic.
Had a thought, could you whip out one of the plastic screw rivets that hold the front infill panel over the radiator and see if that fits? If so, you'd get a number to order. Probably work just as well?
- samuir1974
Appreciate that mate - i like the sound of your idea. Thank you.enuff_zed wrote: ↑Sun Nov 29, 2020 3:53 pm No problem. sorry it took so long.
The weather wasnt playing ball today; but i'll try and get onto that during the week.
- samuir1974
Just to update and conclude on this one - the diagram was wrong - ignore item #5.
4 x item #7 - expanding rivets - installed and securely fixed.
Thanks to those that contributed
- enuff_zed
Good news.samuir1974 wrote: ↑Wed Dec 02, 2020 4:02 pm Just to update and conclude on this one - the diagram was wrong - ignore item #5.
4 x item #4 - expanding rivets - installed and securely fixed.
Thanks for letting us know
- kis
How much were they? I need some for mine!
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- samuir1974
Purchased via eBay i got this pack for £4 +P&P
