Whats wrong? Oil leak?
Josh Andrew
Post by Josh Andrew » Sun Nov 22, 2020 1:35 pm
Hi so I've had a slight issue over the past few weeks every time I really push my car to about 6k 7k and some times by accident past the red line smoke would come from the engine bay and I would open the bonnet to see this, any ideas?
2006 Silver BMW Z4 2.5 SI
enuff_zed
Post by enuff_zed » Sun Nov 22, 2020 1:40 pm
Is that oil being pushed past the filler cap?
If so, looks like too much pressure in there. Possibly CCV blocked?
HQ of 'Norfolk Zed Rescue'.
Danglesberries
Post by Danglesberries » Sun Nov 22, 2020 11:47 pm
Try a new OEM oil cap
firebobby
Post by firebobby » Sun Nov 22, 2020 11:50 pm
Is that mayo under the cap ?
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
colb
Post by colb » Mon Nov 23, 2020 1:18 am
Could wellbe the CCV system blocked causing pressure to build up and force oil past the oil filler cap gasket. If its in the plug wells then suspect the centre plug well gasket under the camshaft cover, they go hard with age and heat cycles and eventually go brittle and crack causing oil to leak into the plug wells. Always fit new main camshaft cover gasket at the same time, they sell gaskets in a kit which includes both gaskets. Depending on model you need to replace the cam cover round rubber seals under the cover retaining bolts as well. Did this on my 2.5 plug well gaskets were very brittle but hadn't developed any leaks like the main gasket had causing oil to drop on the exhaust and smoke. It was only a matter of time before the plug well gaskets let go. Check the condition of the rubber seal under the oil cap, if its bad replace as suggested earlier in this thread. Pull the CCV pipes and see if there is a build up of oily gunge in them, if there is might be time to replace with new kit.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
