Help! Reassembling roof hydraulic pump .....
johnsi02
Post by johnsi02 » Tue Oct 27, 2020 11:14 am
Hi .... roof woes continue.
I now have a working motor. Brought back from the dead!
However, I could really do with some advice about the coupling of the hydraulic pump to the motor itself. On removing the motor bits flew everywhere. This was followed by much swearing :D.
The base of the pump unit has a ball bearing race with a centre mount for the part that actually connects to the motor .... this latter part fell out when removing the motor. There's three little steel pins which I presume fit in the holes on the side of the main piece? And can someone please confirm exactly how the peg (and spring) that connects to the motor should look? And any advice about the easiest way to reattach the motor to the pump gratefully received.
Photos attached. With a bonus picture of the sky over Renfrewshire this morning. Thanks for reading. Ian
Johnsi02 E89 30i sDrive
colb
Post by colb » Thu Nov 05, 2020 3:33 pm
Send Number5 a pm he might be able to tell you what you need to know.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
