Do you park on an incline or something?DSGRNMCM said:Unfortunately I cant put it in the garage, I'm unsure on a car cover, after hearing about rubbing etc.
I was going to give it a good old dry (When/if it stops raining) treat all the glass rubber with some AutoGlym product. Then apply some clear grease on the metal area? or wax the hell out of it?
groovy_hippy said:I too have recently discovered this feature of the Coupe (about 4 weeks into ownership!). My drive is on a slight incline towards the road, and I reverse onto the drive (so, back end of car is lower than the front). I'm wondering if parking forwards onto the drive might be a better idea...
R60BBA said:Just an idea but you could potentially try applying some clear cavity wax in the birdbath.
Dinitrol.DSGRNMCM said:R60BBA said:Just an idea but you could potentially try applying some clear cavity wax in the birdbath.
Do you have a brand name for a good clear wax or a link?
R60BBA said:1998 E31 840Ci Sport
I mentioned cavity wax hence the recommendation of Dinitrol. Yes they do a clear cavity wax. In order to apply it you would have to remove the trims and clean off the area, then once it is fully dry, apply the wax to the internal cavities.DSGRNMCM said:R60BBA said:Dinitrol.
Do they do a clear wax? I could only see (quick look) at under body and cavity filler?
Sorry, can I get some clarification here? Are you asking because you won't be using it over winter and worried about the pooling, or use it very irregularly? How much do you use it (ie how long would the water be pooling on your car)?DSGRNMCM said:Morning All,
This is the first car I have ever owned that has water pooling!
Can I ask how you guys deal with water collecting at the rear of the car at the bottom of the rear window on the boot?
