Whats that sound <<NOW WITH VIDEO!>>
- bigwinn
Now I don't want to be one of those guys who says 'I've got a weird noise what is it'... but
Just any pointers please to help me dig further- 2004 2.2 M54 100K
I have a very slight whistle (ish) noise from the engine. Happens briefly around 1200-1500rpm accelerating, when still or moving, in gear or out, mainly when hot not cold. I did notice it was less with aircon off but then made no difference.
What I've done:
- air filter changed and checked when I did service 2 weeks back
- all hose clips tightened
- DISA valve checked all ok
I'm thinking maybe a belt issue at the front of the engine?
Where would you guys look first?
Stuart
What I've done:
Stuart
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- patriot66
Whats that sound?
I'd bet that it's the small convoluted pipe that branches off the rubber intake boot. The rubber perishes and causes a whistle at low revs/light throttle. Follow the pipe from air filter box to throttle body and you will see the convoluted branch.
Have a good look at it and it will probably be split like in the above photo Sterling Grey '03 2.5i SE / Infinitas Supercharger / S.M.G / Hardtop / Gloss Black 162s / Bilstein B4s / 3.0i Brakes / DLV De-Cat & Silencer / Rebuilt VANOS / Sonar 2Xcite Lights / Carbon & Alcantara Trim / M-Sport Seats / ...& Side Covers !
- bigwinn
Whats that sound?
Nice one- I'll have a look first thing
Stuart
Stuart
EWS Delete PM me
EWS Delete PM me
- sw4nny
Whats that sound?
After owing 3 cars with the m54 engine i have had to replace this part on all of them.patriot66 wrote: ↑Mon Jul 20, 2020 8:27 pm I'd bet that it's the small convoluted pipe that branches off the rubber intake boot. The rubber perishes and causes a whistle at low revs/light throttle. Follow the pipe from air filter box to throttle body and you will see the convoluted branch.images.jpeg
Seems like a good shout to check this out for anyone with an m54 lump
- bigwinn
Whats that sound?
Did some investigating- no obvious splits on the boot but deffo starting to perish/crack
Refitted and immediately no sound, but will see if it does the same hot
Will see if that has fixed it (tightening it all up etc) and go from there
Cheers for the input!
EWS Delete PM me
EWS Delete PM me
- bigwinn
Whats that sound?
Afternoon all
So the sound still lives on
Deffo when hot not cold
Deffo low revs under strain/load
Where next would you recommend?
EWS Delete PM me
EWS Delete PM me
- bigwinn
Whats that sound?
EWS Delete PM me
EWS Delete PM me
- bigwinn
It may be nowt but it does seem worse with aircon ON
EWS Delete PM me
EWS Delete PM me
- kinger
Blackbird..
Current - E89 35is Saphire Black
Previous- E89 35i Space Grey
- bigwinn
EWS Delete PM me
EWS Delete PM me
I had this noise on my first Zed and never got to the bottom of it. Only engine mod I did was change the air filter to a k&n one.
Second Zed had the same noise but only after changing the air filter again. Tried re-fitting and tightening etc but the noise remained.
Might not be this on yours but after I reverted back to stock, the noise went.
Might be worth re-checking fittings after the air filter change.
- bigwinn
I will have another look at the air side... cheers
EWS Delete PM me
EWS Delete PM me
- ph001
Could be oil filter. Weird I know!
- Sgr74
I changed the same hose with the flexi appendage when I fitted a ramair filter and refurbed my disa valve. I love the induction noise and i believe it has a little more get up and go, although it may just be the sound. The fuel consumption seems a bit better, but I have a slight whistle at 2000 revs. I’ve removed and retightened everything and it’s still there. Over the course of the weekend I’m going to put the standard air box back on and try that. I’ll post the result.
Black 2.5 Roadie.
- TheDan
Sorry, to resurrect an old thread bigwinn, but did you ever get to the bottom of this whistle?
