Electrical LCM issue, my own stupid fault 🤬
- ph001
- thecremeegg
The LCM needs to be a lower mileage than the car is on as they have to match the two together - the LCM holds the mileage for the car, hence the tamper light. You can add miles but not take them away. Hopefully it's just something that can be reset.oldgitdave wrote: ↑Thu Jun 11, 2020 7:14 pmOK, I've managed to source a replacement LCM & have fitted it after a chat with my local indy round the corner. And yay it works , all lights back to normal.ph001 wrote: ↑Mon Jun 08, 2020 12:44 pm You can certainly try fitting it on your drive to make sure it restores your indicator function etc first. You will get a mileage tamper light on the dash though as mileage won't tie up so then you will need diagnostics to reset that but at least you can drive safely. If it's just around the corner though I would be tempted to let them fit it. 5 minute job plus 10 minutes coding max.
I am almost certain Quarry motors will be able to sort you out with an LCM module. There is not much demand for them as generally very reliable.
I have the tamper light on as expected but also the airbag light . Maybe there's a tie in with the 'new' LCM as it wasn't on with the old one & I had the battery disconnected the whole time. Anyway no biggy hopefully, she's going in tomorrow morning to have everything reset & coded .
Z4M - Interlagos Blue with Black Leather
Z4 3.0i - Sapphire Black with Red Leather - FOR SALE!
- ronk
Will the tamper light go off when the cars miles catch up to that of the module?
- oldgitdave
I hope that's not the case. How would anyone selling a used LCM know what mileage the recipient car has on it? I certainly have no idea what mileage my replacement LCM has on it but I presumed the LCM was a backup for the speedo mileage.thecremeegg wrote: ↑Sat Jun 13, 2020 1:07 pmThe LCM needs to be a lower mileage than the car is on as they have to match the two together - the LCM holds the mileage for the car, hence the tamper light. You can add miles but not take them away. Hopefully it's just something that can be reset.oldgitdave wrote: ↑Thu Jun 11, 2020 7:14 pmOK, I've managed to source a replacement LCM & have fitted it after a chat with my local indy round the corner. And yay it works , all lights back to normal.ph001 wrote: ↑Mon Jun 08, 2020 12:44 pm You can certainly try fitting it on your drive to make sure it restores your indicator function etc first. You will get a mileage tamper light on the dash though as mileage won't tie up so then you will need diagnostics to reset that but at least you can drive safely. If it's just around the corner though I would be tempted to let them fit it. 5 minute job plus 10 minutes coding max.
My indy round the corner couldn't do the job as he couldn't access the LCM with his software. It's now booked in for 22nd June to be coded by the BMW indy I mentioned earlier. At least I can drive it now .
Zedless
- oldgitdave
I don't think so as the LCM also has the VIN number. Until that's been coded in I'd expect the tamper light would stay on.
Zedless
- thecremeegg
I think it is I'm afraid! It's to stop you adjusting mileage downoldgitdave wrote: ↑Sat Jun 13, 2020 2:35 pmI hope that's not the case. How would anyone selling a used LCM know what mileage the recipient car has on it? I certainly have no idea what mileage my replacement LCM has on it but I presumed the LCM was a backup for the speedo mileage.thecremeegg wrote: ↑Sat Jun 13, 2020 1:07 pmThe LCM needs to be a lower mileage than the car is on as they have to match the two together - the LCM holds the mileage for the car, hence the tamper light. You can add miles but not take them away. Hopefully it's just something that can be reset.oldgitdave wrote: ↑Thu Jun 11, 2020 7:14 pm OK, I've managed to source a replacement LCM & have fitted it after a chat with my local indy round the corner. And yay it works , all lights back to normal.
- ronk
This might be a silly question but ??? If miles can be added, what happens when it goes over the 999,999 max - does it then go to 000,000 ?
- ph001
There is no issue in coding any mileage lcm to the car. The light will definitely not go off by itself when the two mileages ‘catch up’. Where on earth do you dream this stuff up from?
- oldgitdave
- ronk
- ronk
No dreaming ph001thecremeegg wrote: ↑Sat Jun 13, 2020 1:07 pm
It seemed like a logical question to ask after reading this.
- enuff_zed
No such thing as a stupid question. If you don't ask you don't learn.ronk wrote: ↑Mon Jun 15, 2020 10:49 amNo dreaming ph001thecremeegg wrote: ↑Sat Jun 13, 2020 1:07 pm
- ronk
That’s what I was always told as wellenuff_zed wrote: ↑Mon Jun 15, 2020 10:51 amNo such thing as a stupid question. If you don't ask you don't learn.ronk wrote: ↑Mon Jun 15, 2020 10:49 amNo dreaming ph001thecremeegg wrote: ↑Sat Jun 13, 2020 1:07 pm
- oldgitdave
I've asked a few daft ones in my time I can tell you
Zedless
- kis
Might just be the vin number. My airbag ECU needed the vin coded. I don't think it had the mileage coded. Could be wrong... Get them both done, if it's still going in anyway
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
