Another roof post
Another roof post
Ok I've tried the search function and haven't found the same fault as mine. I could be mistaken.
When I hold roof open button I get a solid red light at the same time the windows drop and the roof unlatches. When I remove my finger the light flashes. I can unlock the roof manually and raise and lower. I cant hear the motor working in the rear. Advice on the best place to start welcome. Thanks all
- colb
Another roof post
Check that the parcel shelf in the boot is in the lower position and that the central microswtch is in place and being activated.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
Another roof post
If it was the microswitch there would be an orange light and the roof wouldn't try to move, sounds like the common dead motor.
E85 3.0
Another roof post
Cheers for the feedback. I'll check the drain tomorrow and get a photos of the motor through the boot see if it looks wet.
- colb
Another roof post
The motor is housed in a plastic container that sits in the cavity so you won't see if the motor is waterlogged. You could remove the inspection panel in the rear wheel well and look inside to see the cavity drain. It will have a rubber one way valve on the end of the drain pipe, pull that off and poke something flexible up the drain to check its free or clear of any debris thats blocking it. If you get water out of it then the motor is probably wet and will need to come out. Threads on here showing how to remove it through the boot and relocate it to the boot to avoid futer water getting into it. Be warned its difficult to get the motor out, its held in by nylon tie wraps inside the cavity and those have to be broken using brute force to free it enough to lift the unit out and back into the boot. If you don't feel brave enough there are guys on here ho do it for a price. Did mine myself took most of the day but knowing how now it wouldn't take as long.
Extract from handbook regarding panel lights
Indicator lamps
> The red indicator lamp will light up while
the convertible top is in motion. It goes
out as soon as the opening or closing
operation has been completed
> If the red indicator lamp flashes after
the button has been released, then the
opening or closing operation has not
yet been completed.
The sequence can be continued in the
desired direction by pressing this button
> If the yellow indicator lamp lights up
continuously with the button pressed,
then the convertible top compartment
panel is raised and the convertible top
cannot be moved.
Indicator lamps
yet been completed.
cannot be moved.
- Hood Cavity Drain
- Nearside wheel well drain.JPG (153.84 KiB) Viewed 879 times
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1999 1.8 Z3
2003 2.5 Z4
- Number5
Another roof post
If you can hear the motor running, then check the red hoop in the boot. It sounds like you're not building up any pressure, so you've either got the bypass hoop pulled, or you've got a hydraulic leak.
Send me a PM if you're near enough to me and want me to take a look
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- wonkydonkey
Another roof post
As you can't hear the motor working, it rather sounds like it might be time to dig it out and take a look/relocate it.
Previous:
~2006 Z4MR in Silver Grey
~2003 3.0i E85 in Sterling Grey
Click here for the Sticky Steering thread
<My name is James>
<My name is James>
- Number5
Another roof post
All sorted, The roof motor was submerged and not spinning.
I've now relocated it to the boot and got the original motor working again.
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- Number5
Another roof post
No Problem. Nice to meet you yesterday ( at a distance !!) and glad to be of help
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Another roof post
I've popped you a recommendation on facebook z4 owners uk if that's ok?
- wonkydonkey
Another roof post
Previous:
<My name is James>
<My name is James>
- Number5
Another roof post
Thank you. Much appreciated.
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Another roof post
looks like a great mod to carry out
- Number5
Another roof post
Here are my pics of a typical move:-
Relocated to back corner Hidden by matching false carpet panel
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
