Rough idle
Rough idle
Folks
The Z4 sits for a while in between uses. A couple of time when I've fired it up it has a super rough idle, once it also took a few attempts to start.
Once running it simply clears and is fine.
Are there any know causes for this, a common fault maybe ?
Cheers all.
Cheers all.
- enuff_zed
Rough idle
Leaking injector? flooding a cylinder?
- baconJazz
Rough idle
Dirty MAF sensor ?
2007 3.0si sport e86 coupe Black Sapphire 93k and rising at approx 2k a year.
Mazda mx5 mk3
Fiesta ST
Subaru WRX Blob eye
Mini Cooper S JCW
Mx5 mk1
Ford Puma.
Opel Manta GTE (1984)
Mk 1 Ford Capri 1.6 GT (1973)
Austin Maxi 1750 HL (269 BC)
Mazda mx5 mk3
Fiesta ST
Subaru WRX Blob eye
Mini Cooper S JCW
Mx5 mk1
Ford Puma.
Rough idle
Will have a look at the MAF first.
Thanks for the ideas
- enuff_zed
Rough idle
If not that then leave it a few days to sit, then whip the plugs out and see if there's a wet one.
- Smartbear
Rough idle
Low battery possibly, try measuring the voltage after it’s been sitting for a while
e85 3.0si sold
- ph001
Rough idle
Please state what engine you have! If it’s the M54 it could be a split in the intake hose like this...
viewtopic.php?f=11&t=120521&hilit=Hose
- enuff_zed
Rough idle
A point I am keeping in mind for wifey's M54, just in case.ph001 wrote: ↑Wed Mar 11, 2020 10:01 pm Please state what engine you have! If it’s the M54 it could be a split in the intake hose like this...
However, would the OPs idle clear itself if it were this?
I was surmising an issue that cured itself as things warmed up?
Rough idle
It's the 2.2
I've had the split hose thing before, it's not that. It clears once running for a minute or even less.
Battery is a good shout as it has a habit of going flat just now. Could just be a low voltage.
Will check all these when the chance allows.
Thanks for the ideas again.
- ph001
Rough idle
In that case you have to start by changing the battery and eliminate it if nothing else.
Rough idle
Been a while lol
It was the ICV needing a good clean.
