You may well have found the source of your problem!
Ofc any flex hose needs to be open and not flat in order to operate efficiently.
Anyway you can brace it open at where it’s flat, with a clamp or something, then trying to run the engine in order to cancel it out as the issue?
It sounds like it’s worth replacing in any case.
Cleaning your maf also doesn’t guarantee it’s going to work again if thats the issue.
Try unplugging the electrical connector for the maf then starting to see if that makes a difference. It wont do any damage.
Engine mis firing
- Chris_D
Engine mis firing
