DSC Sensor Interchangeability face-lift/preface-lift 3452 6769174
I have a Z4 2009 which has the trifecta problem. My mechanic has removed the YAW sensor code 3452 6769174 and says that it is faulty as it was sitting in a pool of water?! Reading the forum and unable to locate a replacement part (apart from BMW at a cost of circa £500) I purchased part 34526764018 which has been stated as interchangeable. My mechanic has said that there is an ABS light coming up which cant clear. It has a lateral accelerator code - 5E34, My mechanic cant clear – maybe his coding equipment isn’t up to it – his words. Any ideas of what I should now do? Thanks in advance
I seem to remember that there is an option to calibrate the sensor in INPA. Worth a shot.dougis2004 wrote: ↑Fri Nov 27, 2020 2:44 pm My mechanic cant clear – maybe his coding equipment isn’t up to it
2006 Z4 2.0i Ruby Black
- ph001
Good pic - that's the first time I have actually seen what the lateral acceleration / YAW sensor looks like. I guess you have to remove the drivers seat to get to it?
Thanks Jfgoldfish
I'm a bit of a novice with INPA and not sure who can provide this service - I do have a number of readers specific for BMW (Left them in a bundle from a decessed relative) I'm not sure if any of them might offer this service better. I intend to take the readers to my mechanic and see if any provide the INPA service. Perhaps you know? They are;
KESU C101
For BMW OBD -2
C110+ BMW SCANNER- with disc Creator and USB
Worth asking as I might waste my mechanics time (and look stupid)
Thanks in advance
KESU C101
For BMW OBD -2
Thanks in advance
Folks like myself would be more than happy to plug your car in and do some basic diagnostics. I am in Northampton area.dougis2004 wrote: ↑Mon Nov 30, 2020 1:57 pm I'm a bit of a novice with INPA and not sure who can provide this service - I do have a number of readers specific for BMW
The C110 is meant to be a good code reader for the money but I doubt it can recalibrate sensors. I may be wrong.
I have very little experience with other code readers outside of my very cheap foxwell and the BMW software suite I run on an old laptop so I can't comment on the others you have there.
Guess I'm in the same boat,
wet carpets, lights trifecta, dead speed sensor (34526769174)
Z4 2008 Roadster 3.0i error code 5D8C (also seems to have triggered related codes before dying: 5E19, 5DC3, 5DA3, 5D93, 5DF4)
Anyone else successfully fitted the 34526764018 as a replacement (vs original 34526769174) ?
Will probably setup INPA later this year but I understand that the sensor shouldn't require reprogramming once swapped, right?
Thanks!
Thanks!
Hello, first time post.
I’ve installed 34526764018 in a post facelift car (original installed Part Number was 34526769174) I’ve had some success, but am unable to run the longitudinal calibration in INPA.
INPA is communicating with the sensor, as I can run the lateral calibration and am down to only having a yellow brake light.
When running the longitudinal calibration, INPA throws an ECU conditions not correct error and the MK60 module error log shows an error 5E34.
Any help would be appreciated, thanks!
Exact Same scenario here ; ( installed 34526764018 in a post facelift car - original installed Part Number was 34526769174)Miragefour wrote: ↑Mon Aug 30, 2021 5:27 pm Hello, first time post.
did you manage to clear the yellow brake light?
I do have INPA working but haven't tried the calibration yet. Will probably do so tomorrow.
Is the calibration option easy to find in the menus?
Can you confirm under which module name or number / sub-menu ?
Thanks!
Chrisd928 wrote: ↑Sat Dec 21, 2019 7:14 pm Edit Solved:
The prefacelift dsc sensor part no 34526764018 does work on a facelift E86. Way cheaper than the facelift part number 3452 6769174. This sensor throws error code 5E38. hope this helps someone with the dreaded 'trifecta' of tcs, tyre warning and handrake lit in yellow.
Hi guys,
I Had the trifecta of lights on the dash (dsc, handbrake and pad warning) all in orange.
I read the codes (dis V57) and got 5E38 which is the dsc sensor located under the drivers seat, as well as others for wheel speed sensor etc which are now all sorted, (full new knuckle, hub and sensor etc) . I have removed the unit and the part number is 3452 6769174-03, these seem rare as only fitted to face lift E85/E86.
The earlier pre face-lift unit is part no 34526764018 which real oem seems to say is exchangeable retrospectively, but it doesn't seem to be the same in reverse, or am I reading it wrong?
https://www.realoem.com/bmw/enUS/part?i ... 4526769174
https://www.realoem.com/bmw/enUS/part?i ... 4526764018
Can anyone tell me if the pre Face-lift version will work on a face-lift E86? plenty of the earlier part around but later one seems rare and expensive (£230 to send away for repair, £550 ish new).
Alternatively if anyone has one going for a fair price then that would be great!
Thanks in Advance for any input
Hi Chris, can you confirm that the handbrake yellow light disappeared right away with no other changes or software/firmware update? I still get the yellow handbrake light and at least another poster has the same issue so looking for solutions. I have INPA and NCS installed.
Thx
Come on Chris put us out of our mystery please
- Karim_Z4
Did any one get to the bottom of this? I have also just installed a pre facelift sensor which has removed the three warning lights but still left with a yellow handbrake warning light. Any help would be really appreciated as I can’t bring my self to pay £500 for the post facelift sensor.
E85 2007 Z4 2.0I Space Metallic Grey
Unfortunately the 34526769174 part is the only one that works on the facelift cars. My advice is to do what I did and search the secondhand car parts in North America. I found one very quickly over there and the total cost including delivery was $220. Please beware there is import duty from the USA. This was by far the cheapest way to sort the problem. I even tried E46 sensor all sensors I tried 3 in total all gave an error. But the correct part from America fixed the issue straight away.
- Karim_Z4
Thank you for the quick reply, any chance you have a link to the website you used to search for the part as i will try that before giving up and buying a new one. TIAffc1971chris wrote: ↑Thu Jun 30, 2022 10:40 am Unfortunately the 34526769174 part is the only one that works on the facelift cars. My advice is to do what I did and search the secondhand car parts in North America. I found one very quickly over there and the total cost including delivery was $220. Please beware there is import duty from the USA. This was by far the cheapest way to sort the problem. I even tried E46 sensor all sensors I tried 3 in total all gave an error. But the correct part from America fixed the issue straight away.
I found the part on Facebook. I used a US owners group on FB.
