E85 3.0si rough idle / “thwacking” noise?
A local garage serviced it, when owned by previous owner. I’ll change the oil myself with LL04 spec before next summer when I get it out of the garage and take it off SORN. Castrol Magnatec can be bought LL04 I think?
2006 E85 3.0si Manual, Titanium Silver, Red Leather, Gunmetal MV2s, Piano Black, ZHP.
- JamieZ4C
Indeed it can and it's currently on special offer at Halfords
Edit... Scrap that, I just checked their website and it's back up to normal price
Thanks Jamie! (I actually got 4L of 50% off Magnatec from Halfords when it was on offer the other day, as Z needed +1L top up) - guess mixing oil types could cause a noise?
- skelters
Have you had the codes read to see if there's anything that might be causing an issue?
2007 Z4 3.0si Sport. Silver Grey Metallic, Brembo Brakes, HEL Braided Brake Hoses, Machine Monkey Exhaust Tips, Stubby, Piano Black trim, Black Leather, Bilstein B12-Pro-Kit, Michelin Pilot Sport 4 on MV2's. Roof Motor in the Boot!
- JamieZ4C
Re mixing oil, I don't think it's recommended, although I haven't a clue if it would cause your symptoms.
I say give it an oil and filter change and take it out for a good long blast (preferably on the most fun roads you know - it's what owning a zed is all about )
Hi skelters,
Not yet, as don’t have a code reader and don’t want to go to the Stealership! That said, I’ll try and find a local BMW specialist if it continues.
Cheers,
George
Cheers,
George
- skelters
There's a thread on the forum for Who Has Carly.
Someone close will be able to check for any error codes.
Where are you?
Where are you?
Hi Skelters,
That would be amazing! Bromsgrove, so Birmingham-way?
- wonkydonkey
Guys, don't forget that Halfords do price matching. I bought three 5 litre bottles of Castrol Edge to do my Z4 and the Audi and saved something like £40 by price matching an online shop I've used before. It'll knock the socks of most special offers!
Previous:
~2006 Z4MR in Silver Grey
~2003 3.0i E85 in Sterling Grey
Click here for the Sticky Steering thread
<My name is James>
<My name is James>
- skelters
Does it make that noise from start when cold. I ask because I have just had a mechanic out to my Ford Focus (day car) which is making a similar noise. Only does it when engine gets hot. Mechanic says its the typical noise of a timing chain tensioner on the way out. This can effect engine timing and cause rough idling as well as that noise.
Hi Mike, thanks for that, much appreciated. Does it all of the time, but seems to have quietened down a bit now after an exuberant run out on Sat eve in the sun Will keep my ear out next time it starts cold and also after a good run when hot
As per migizi....check your Diza valve.
Cheers, Steve
'03 Z4 3.0i Merlot, Cream leather interior.
6 spd manual, stubby, Michelin Pilot Sports.
- srhutch
- Moderator
As you can see from that happened from 2k on the clock and the car was doing 2 x 25 mile trips per day or every other day with no short journeys, which throws a lot of the usual causes such as short journey and lack off use out of the window.skelters wrote: ↑Thu Sep 05, 2019 10:21 am Here's the worst, worst case....
viewtopic.php?t=10937
What's the mileage on the car?
Which oil is in the car?
OP’s sounds normal though, just injector noise. Hearing sound on video though can be difficult.
Thanks guys. Re. DISA valve - didn’t the N52 (3.0si) get a revised DISA that is meant not to have the same issues as on the M54 (pre-2006) Z’s?
Cheers,
George
Cheers,
George
