brake woes2
- road warrior
brake woes2
I have ordered a caliper for my driver front, but.. I wondering now, having stated the brake problems go away after spraying copper grease onto the assembly I used a temperature laser on both fronts after a run and discovered my left front was warmer
So It seems both get warm, or binding to lessor degrees. I'm now dubious that copper grease would affect a binding caliper so what issues do I have? What about the carrier bolts? When not "binding" or overheating the brakes work fine and pull up equally.
If you ever think I'm off my rocker.. Just put me back in it and walk away... It's the kindest thing
My wife says I never listen - or something like that.
gone but not forgotton -Mean Steve - made a sound like a bear with his nuts in a trap.
- Nictrix
brake woes2
The only real way to find out is to take the wheel and start stripping down the brakes, as you are removing the caliper check how tight the pads are in the carrier, check how easy the piston pushes back into the caliper and with the pads removed check if the caliper moves easily on the sliders.
That would rule a lot of things out.
- ph001
brake woes2
It's almost always the piston sticking in the caliper bores. The refurb solution (which is rarely worth the time and effort) is to strip them, pop the bores out with hydraulic action or compressed air and inspect the bores and seals. Almost certainly will need new seals and bore cleanup from any rust traces as a minimum. Buying a refurbed set is just as good as new imho and you get a good cost saving.
- dhobbs
brake woes2
Don’t use copper grease on rubber seals, it makes them expand. Silicon grease is best for rubber.
(Sorry, don’t want to teach you to suck eggs, but it’s something I learnt recently)
3.0si roadster. Requisite stubby. Sound gen mod. LED numberplate lights. LED boot strip. Interior lights LED too. ZHP gearknob. Daily drive
Motor in boot. Bilstein B8 dampers. New radio, much better sounds
- dhobbs
brake woes2
I always clean the sliding pins/bolts with wet and dry, and apply silicone grease. Although the rubber boots should be new with the Caliper so doubt the problem is there.
- road warrior
brake woes2
thanks - but im not sure silicon grease will withstand heat and just simply heat up and disperse
- dhobbs
brake woes2
To be honest I’m concerned about that too. Not sure what temperatures the brake operate at. I’ll check with my grease tonight to see if has a rating.
Got to replace my rear callipers at some point as I believe they’re sticking too.
- ph001
brake woes2
Silicone grease melting point is around 200’C...no way that will be an issue on your calipers. It’s not like vaseline!
- Ewazix
brake woes2
When I overhauled my brakes a couple of years ago I went with refurbished calipers, I was surprised to read on TIS that you are NOT supposed to use any grease or lubricant on the slide pins,. They have a chromed finish and are best replaced once grotty or pitted, mine were 'dull' even after buffing up so I replaced them.
I appreciate that lots of people do lube the pins and there will be deluge of comments to the contrary but that is the official BMW procedure. I guess it's because grease of any kind attracts dirt and eventually gums up the pins.
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- PinkPineapple44
brake woes2
Came here to say this ^^^ I've always used silicone grease on my sliders, rebuilt a set of rear calipers 8 years ago and recently had to replace the pads (drift car so not everyday use but hard use) and the grease was still intact and sliders rot free. I cleaned the pins and boots and replaced with new silicone grease anyway as I like to be thorough.
You can also buy high temp silicone grease which goes to about 300 iirc.
- road warrior
brake woes2
all very good information and im learning .. up until now (something) is seizing i have not used any grease of any kind and was only used now as a get you home situation, as stated something seized 7 months go, then went away till last week
- Jembo
brake woes2
I did this on my ole 3.0
viewtopic.php?f=24&t=8399
I can only say from personal experience heat disbursement & braking issues will be a thing of the past if you do this...
- C4C24D31-A54E-4CCD-9EC4-8579A35785C2.jpeg (233.12 KiB) Viewed 622 times
Lifer 54
Lifer 54
