Suspension out at rear according to garage - Eibach springs and lowered 30mm
Hi - My car is in the garage after a bump to the left rear wheel arch, they say the suspension is slightly out at rear but as its not OEM and is lowered (30mm on Eibach springs) it would be slightly "off".
Does this sound right?
Does anyone have any numbers i can share that would indicate correct range?
06 E85 Titanium Silver 2.5si
Top down
Grin on face
Will always wave
Top down
Grin on face
Will always wave
- ben g
What do they mean when they say it's slightly out? Are they saying somethings broken or that the alignment is out of factory spec?
If the latter, then Eibachs would most likely be the cause of this.
Also, rear trailing arm bushes do require replacing on Z4's. That could also give a dodgy alignment reading, if that's what they're talking about.
Thanks Ben, it's not broken (although he said it was very rusty - 15 years old Zed.... ) - i think he is saying its out of alignment with factory spec. But how far out of alignment i'm not sure... i will ask him about the trailing arm bushes.. Thanks!
Top down
Grin on face
Will always wave
Top down
Grin on face
Will always wave
- R60BBA
Have they done a wheel alignment to confirm this?ROBOTCOWBELL wrote: ↑Mon Jun 10, 2019 11:03 am Hi - My car is in the garage after a bump to the left rear wheel arch, they say the suspension is slightly out at rear but as its not OEM and is lowered (30mm on Eibach springs) it would be slightly "off".
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
When I put Eibachs on my Focus ST, by lowering it by the 30mm or so, as spec, it then pushed the camber of the rear wheels out , which then caused the inner edges of the tyres to wear as the weight of the car was then pushing on that. it made about 2.5 deg negative on my home made camber gauge. Perhaps that is what they are talking about. I bought for the ST, some camber adjustment bolts made by Eibach , which are an ovalised bolt to then adjust the camber back to the 0.5 deg neg camber which then stopped the wear and the car sat better too. I suspect that making large drops in suspension height on the Zed , may well have caused something similar with the geometry. The wheel will not work on a perfect line when you drop suspension.
E86 In sapphire black
Is it out of spec by the same amount, on both sides
I finally have the geometry, any thoughts on this welcome
Top down
Grin on face
Will always wave
Top down
Grin on face
Will always wave
That will eat the inside of the rear tyres with camber like that. NSF is too much as well, hence why they are showing red.
Why is the 'after' almost identical to the 'before'?
You'd want it to be in the green everywhere to get it back to 'stock'.
Also, if they're using a Hunter system, then need to tell it you've got lowering springs on it, otherwise the 'target' figures will be wrong.
- R60BBA
Who did this job? Stevie Wonder?ROBOTCOWBELL wrote: ↑Sat Jun 15, 2019 2:39 pm I finally have the geometry, any thoughts on this welcome IMG_1778.jpg
Way too much negative camber at the back.
In reg to the front, for a sporty drive you could run -1.5 but both your left and right would have to be at -1.5 as opposed to just your left being at -1.5 and your right at 0.38.
Not being funny but I wouldn’t pay for that until they got the car within tolerances (which would mean all the icons would be green as opposed to red).
- R60BBA
These are the tolerances for your motor.
- DF653C18-1C29-433C-AB45-CAA32B48E98E.jpeg (154.98 KiB) Viewed 1081 times
Thanks for sharing this. Are these the tolerances with it lowered etc? So I could pass this to the garage?
Top down
Grin on face
Will always wave
Top down
Grin on face
Will always wave
- R60BBA
Ahh yes sorry the above is for the 3.0 on m sport suspension.ROBOTCOWBELL wrote: ↑Mon Jun 17, 2019 7:11 amThanks for sharing this. Are these the tolerances with it lowered etc? So I could pass this to the garage?
The below is for your 2.2 on SE suspension.
Taken from here: https://www.newtis.info/tisv2/a/en/e85- ... t/3lctg8QV
- 78190535-6C27-40C4-815A-86632077E85F.jpeg (178.37 KiB) Viewed 1028 times
Sadly MOT failed and now looking like this is becoming an expensive project that I'm not really skilled for so will be putting my Zed up for sale for someone to hopefully take on as a bargain and bring back to glory. I have found one I like for sale on Facebook and viewing Friday, fingers crossed.....
To be continued.....
Thanks all for your advice
Top down
Grin on face
Will always wave
Top down
Grin on face
Will always wave
It hasnt failed on much. The front spring explains why that is out on the print out. Seems sad to let it go for a set of shocks, a drop link and a couple of bulbs !!
