Euro lights
Euro lights
I’d suggest LEDriving premium from OSRAM. You’ll get better output with no colour on the bulb and it will last longer. Not sure if the fog is monitored, if so code out the checks.
- Timmyboybunter
Euro lights
Here's my chromed red lights fron the link above, delivered in a frigging jiffy bag. Sigh.
- 20190508_182914.jpg (156.89 KiB) Viewed 753 times
2012 VW Passat 1.4 Tsi Estate
2005 Mercedes CLK 55 AMG
2015 E89 BMW Z4 sDrive35iS (sold)
2010 E89 BMW Z4 sDrive30i (sold)
2003 E85 BMW Z4 3.0 (sold)
- ben g
Euro lights
that's ridiculous The seller must be a complete moron.
- Timmyboybunter
Euro lights
It gave me a good laugh at least
Euro lights
Get the OSRAM, good excuse now. About £15 the pair on Amazon
Euro lights
- Timmyboybunter
Euro lights
Thanks for the link - do you know if that would throw up any error codes?
Euro lights
I don’t have a pre facelift, but if the bulbs are monitored then they will. Easy test, unplug bulb and see if you get a warning. If so then need Carly or ncs to code out the check. Worth the hassle for LED vs bulb imho
- Timmyboybunter
Euro lights
Ok thanks - they are monitored from what I've read, but I have Carly so no problem.
- MACK
Euro lights
The fog is checked and carly doesn't give you the option on the fog to code it out. I asked carly to add it and basically got a response of "the E85 is a really old car now and we prioritise the newer stuff so won't be doing anything with your request" talk about customer service!Timmyboybunter wrote: ↑Sat May 11, 2019 7:00 pm Thanks for the link - do you know if that would throw up any error codes?
I've got the 4 white spots rear lights on mine and I've got some extra bright canbus leds in white in mine from halfords. I use the fog as an extra reversing light when needed. I never really use mine as a fog but if I did its a quick switch to the red bulb. When I start mine the fog flashes faintly about 10 times which is the light unit doing its self testing to make sure everything works. On non led bulbs there isn't enough current sent to light the bulb so you never see it flash, but obviously leds are different and there's just enough to make it work faintly
Silver 05 3.0i SE
White E89 20i M Sport
- Timmyboybunter
Euro lights
Thanks for the info - I've ordered the LED bulbs now
I have INPA up and running, can that disable the fog light monitoring perhaps?
Euro lights
Nope but if you can manage to install INPA then NCS (and ncs dummy) is easy and can do everything available.
- Timmyboybunter
Euro lights
Cheers - completed using NCS today, little bit daunting for a first timer but very easy come the end.Scooba_Steve wrote: ↑Sun May 12, 2019 10:15 am Nope but if you can manage to install INPA then NCS (and ncs dummy) is easy and can do everything available.
Disabled cold and hot monitoring for the rear fog, dash warning has gone away. Result
- MACK
Euro lights
What were the lines of code you changed? I need to have a go at this myself.Timmyboybunter wrote: ↑Tue May 28, 2019 11:20 amCheers - completed using NCS today, little bit daunting for a first timer but very easy come the end.Scooba_Steve wrote: ↑Sun May 12, 2019 10:15 am Nope but if you can manage to install INPA then NCS (and ncs dummy) is easy and can do everything available.
Silver 05 3.0i SE
