Shaking steering wheel 60-85mph
I felt vibration with the wheel being one 5g weight out, so quite sensitive. Lost of places just use 10g weights.
So if you have the 8.5's on the rear, jack the back and with the wheels off the ground, put it in gear and see if you can detect any wobble.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Is it possible that the tyre got damaged when it was removed from the old rim? I’ve checked the dates on the tyres and they are from the back end of 2013 so will be hardening up I would imagine.road warrior wrote: ↑Fri Apr 12, 2019 10:38 pm I will just ask.. These ain't bloody runflats are they?
So you put your good used tyres back on the front of the new rims yes?
OK well this is just observed experience here, I have no documented proof but I will share
I observed when I did the same as you I experienced a similar action. You see.. A tyre settles in to the rim as it wears, so when you take the tyre off the rim and put it onto another rim you will have highs and lows points on the tyre that will now have to re bed in. You have 2 choices. Be patient as it will take maybe 500 miles to re settle, or try them on the back and put the new tyres on the front. I recommend the latter, as you can still bed the tyres in on the back but with reduced vibrations hopefully. There remains the question of the rims but that's up-to you to know.
- road warrior
time to buy some tyres i think , IF your sure your new rims are any good that is, im currently sourcing these SUMMER TYRE Falken AZENIS FK510 225/40 ZR18 92Y XL with MFS BSW for 70 quid a corner delivered - very very highly rated - when you have them put on ask him to spin up the rims before putting the tyres on to check the rimsthecookie125 wrote: ↑Tue Apr 16, 2019 7:52 pmIs it possible that the tyre got damaged when it was removed from the old rim? I’ve checked the dates on the tyres and they are from the back end of 2013 so will be hardening up I would imagine.road warrior wrote: ↑Fri Apr 12, 2019 10:38 pm I will just ask.. These ain't bloody runflats are they?
If you ever think I'm off my rocker.. Just put me back in it and walk away... It's the kindest thing
My wife says I never listen - or something like that.
gone but not forgotton -Mean Steve - made a sound like a bear with his nuts in a trap.
Are these wheels 108s and have they been newly refurbished if so check the points of the centre stars are flush with the outer rim if they are not seated properly they can cause an imbalance
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
- MACK
Just to recap and to make sure we are all on the same page.
You said you bought new wheels, I've took this to mean we are talking aftermarket ones here not a recon set of originals as suggested above, is this correct? You've already proved the issue looks like a wheel balance issue on the front wheels as it vanishes when the wheels are swapped front to rear. that just leaves the wheels and the tyres as possibilities.
Here's a few things to check before throwing any more money at it. Have a look at the front wheels and count how much weight has been added, it will give you a good indication of how good the wheel/tyres are. Lots of weights usually points to few things;
Poorly manufactured wheels.
Cheap tyres- these often need more weights than premium brand equivalents
Badly/unevenly worn tyres.
Beyond the wheel weights themselves this can also be due to a slightly out of shape wheel or tyre. I seen this first hand with cheap aftermarket wheels and cheap tyres. In fact in the case I saw with 4 brand new cheap tyres the car also made a right old din like the wheel bearings had gone.
As I've said it can only be either one or both of the wheels or the tyres. I know you trust the place you have used, but the thing to do now is go to another reputable tyre fitter and see if the balancing is actual as it should be, this eliminates a dodgy balancing machine from the equation. I would also be looking at the wheels and make sure the inside surface where the bolts go through/meets the hub has not been painted. On both aftermarket and recon original wheels painting this face can cause exactly the issues your having.
Silver 05 3.0i SE
White E89 20i M Sport
Hi, I had the same problem. It was my front left caliper sticking, I had the caliper removed and repaired, the brake fluid pressure increased, new disks on the front and new pads and the problem disapeared completely. I have a video somewhere, you can really see the wheel shaking violently. Mine happened at around 40-60 mph.
The way to check it is one of your calipers is if you take it for a drive so it does the shaking and then check the temperature of the front two brake pads (dont touch them, you can feel the heat from putting your hand near to them). If one is noticeably hotter than the other, its your caliper.
- road warrior
he has said the problem goes away if he swaps the wheels round.NickSalf wrote: ↑Wed Apr 17, 2019 8:59 am Hi, I had the same problem. It was my front left caliper sticking, I had the caliper removed and repaired, the brake fluid pressure increased, new disks on the front and new pads and the problem disapeared completely. I have a video somewhere, you can really see the wheel shaking violently. Mine happened at around 40-60 mph.
just saw the 108 spec my badMACK wrote: ↑Wed Apr 17, 2019 8:30 am Just to recap and to make sure we are all on the same page.
It points to the front wheels/tyres, so it's either a bad tyre or the wheel is buckled. Tyres can get damaged, so you need to really check these carefully.
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
To recap,
Other thing thats worth mentioning is the the wheels have got 5g weights on them and all of them look equal across the rims (between 3-5 on the inner and outer edges)
- These are aftermarket wheels, brand new & never opened
- I swapped my original 2013 sport contact 5 tires onto the fronts and had brand new sport contact 5s to match on the back
- As soon as I put the wheels on the car I got a shaking steering wheel above 60mph, one of the new wheels was littered with wheel weights, originally they blamed the tire at been slightly out of shape. After two goes at balancing the wheel was then blamed for the shaking due to it been buckled
- I took it to a trusted indie who gave the same diagnosis
- received a new wheel from the company, replaced the out of round wheel and balanced to 0-0 with very little weights, shaking still present
- Indie balanced the remaining wheels which where all about 5g out to 0-0, while doing this reported that the inner and outer edges of the RIM where fine, having dealt with the previous problem the tech was looking for anything abnormal across the rest of the wheels, all the wheels now have a normal amount of weights on them, shaking still present
- I then removed the wheels myself and checked all bushes/mountings where tight, drove the car approx 20 miles to check the calipers which where all at equal temp, discs have also been replaced within the last 6 months
- Wheels then swapped front front to back axle where the shaking the wheel stopped
- Reported this to the indie who said that one of the front tires did have a slight bit of movement in it
Yes I agree, thanks for the offer on those if it had been 3 weeks ago I would have said yes but I want matching ones across the car and have just spent £280 on the rearsroad warrior wrote: ↑Tue Apr 16, 2019 8:03 pmtime to buy some tyres i think , IF your sure your new rims are any good that is, im currently sourcing these SUMMER TYRE Falken AZENIS FK510 225/40 ZR18 92Y XL with MFS BSW for 70 quid a corner delivered - very very highly rated - when you have them put on ask him to spin up the rims before putting the tyres on to check the rimsthecookie125 wrote: ↑Tue Apr 16, 2019 7:52 pmIs it possible that the tyre got damaged when it was removed from the old rim? I’ve checked the dates on the tyres and they are from the back end of 2013 so will be hardening up I would imagine.road warrior wrote: ↑Fri Apr 12, 2019 10:38 pm I will just ask.. These ain't bloody runflats are they?
- road warrior
oops,thecookie125 wrote: ↑Wed Apr 17, 2019 2:09 pmYes I agree, thanks for the offer on those if it had been 3 weeks ago I would have said yes but I want matching ones across the car and have just spent £280 on the rearsroad warrior wrote: ↑Tue Apr 16, 2019 8:03 pmtime to buy some tyres i think , IF your sure your new rims are any good that is, im currently sourcing these SUMMER TYRE Falken AZENIS FK510 225/40 ZR18 92Y XL with MFS BSW for 70 quid a corner delivered - very very highly rated - when you have them put on ask him to spin up the rims before putting the tyres on to check the rimsthecookie125 wrote: ↑Tue Apr 16, 2019 7:52 pm Is it possible that the tyre got damaged when it was removed from the old rim? I’ve checked the dates on the tyres and they are from the back end of 2013 so will be hardening up I would imagine.
but dont you still need 2 fronts ?
Yeah I do but I want them to be matching with the ones on the back so it's uniform if you see what I mean, think SC5's are £180 fitted looking at prices on the fronts.road warrior wrote: ↑Wed Apr 17, 2019 2:12 pmoops,thecookie125 wrote: ↑Wed Apr 17, 2019 2:09 pmYes I agree, thanks for the offer on those if it had been 3 weeks ago I would have said yes but I want matching ones across the car and have just spent £280 on the rearsroad warrior wrote: ↑Tue Apr 16, 2019 8:03 pm time to buy some tyres i think , IF your sure your new rims are any good that is, im currently sourcing these SUMMER TYRE Falken AZENIS FK510 225/40 ZR18 92Y XL with MFS BSW for 70 quid a corner delivered - very very highly rated - when you have them put on ask him to spin up the rims before putting the tyres on to check the rims
Just had new tyres fitted to the front so will update soon as I've driven it
