Steering
Steering
The last time I spoke to my repairer he could not see where this “eccentric ring”
Was- for adjusting.i assume but don’t know,it is on the top of the steering unit.
Still have not solved the problem-if it can be solved,! I guess this is a design problem.what a pain.
- paullyjay
Steering
I have the same issue starting to appear in my steering only when the weather is super hot - how easy is it to adjust and do I need to be a contortionist?wonkydonkey wrote: ↑Sat Apr 13, 2019 6:28 pm firebobby I haven't heard from him - unsurprising really when a stranger calling himself wonkydonkey offers to look at your wayward steering
- wonkydonkey
Steering
There's an extensive thread about this problem. If yours is exacerbated by heat, it's highly likely that you'll be able to resolve it by following the instructions in the thread for adjusting the ring:paullyjay wrote: ↑Mon May 06, 2019 3:47 pmI have the same issue starting to appear in my steering only when the weather is super hot - how easy is it to adjust and do I need to be a contortionist?wonkydonkey wrote: ↑Sat Apr 13, 2019 6:28 pm firebobby I haven't heard from him - unsurprising really when a stranger calling himself wonkydonkey offers to look at your wayward steering
viewtopic.php?f=3&t=100725
Previous:
~2006 Z4MR in Silver Grey
~2003 3.0i E85 in Sterling Grey
Click here for the Sticky Steering thread
<My name is James>
<My name is James>
- wonkydonkey
Steering
Update
I thought I should come back to this thread to wrap it up with a verdict to help others with the same issue. Viv brought his car down to me last weekend and sure enough, with the front wheels in the air, it felt like sticky steering to me. Since I haven't carried out a sticky steering adjustment since last summer, I made the schoolboy error of adjusting the steering wheel to the fully UP position rather than fully DOWN, which made access to the pinch bolts unnecessarily difficult. I find mistakes like this are much more likely to happen while you're talking to someone or being watched, so I'll just blame Viv for that, and anything else I got wrong that week Anyway, I was able to adjust the eccentric ring eventually.
My oversight made the job take much longer than it should've taken - probably an hour or more - but the feel in the steering wheel eventually came back to being as good as I feel the Z4 EPS can feel. I've asked Viv to come back to me if he thinks it needs any further adjustment, but his was probably the worst case of sticky steering I've felt to date!
Previous:
<My name is James>
<My name is James>
- wonkydonkey
Steering
I posted a link to the Sticky Steering thread above, Paul. All the info you should need is in there, including the advice to adjust the steering wheel all the way out and all the way down it normally takes me 3 minutes to undo the two pinch bolts but took me over half an hour because I forgot that simple step in the process!
Previous:
<My name is James>
<My name is James>
- paullyjay
Steering
Yeah, I read it all through, but I can't see how to get the torx socket onto one of the bolts. When I had a look at the steering adjustment, ironically I was in the middle of fitting some e46 sport seats to make the seating position better for my back and in the process tweaked my back... I'll re-visit this when my back is feeling better and I can squeeze myself under the steering column again!wonkydonkey wrote: ↑Sun May 19, 2019 5:50 pmI posted a link to the Sticky Steering thread above, Paul. All the info you should need is in there, including the advice to adjust the steering wheel all the way out and all the way down it normally takes me 3 minutes to undo the two pinch bolts but took me over half an hour because I forgot that simple step in the process!
- wonkydonkey
Steering
paullyjay to my mind, using a socket instead of a spanner will make access even more difficult because you need to take up more room. See how you go though. Sorry to hear about the back! The standard seats were painfully uncomfortable for me too, so I fitted E46 M3 seats last month. Massive comfort improvement, but what people DIDN'T say was that the lowest position is now about 3" higher than I want to be!
Previous:
<My name is James>
<My name is James>
Steering
Solidly amused by this. But good on you for having a look at it in the end!wonkydonkey wrote: ↑Sat Apr 13, 2019 6:28 pm firebobby I haven't heard from him - unsurprising really when a stranger calling himself wonkydonkey offers to look at your wayward steering
E86 | Stratus Grey
- wonkydonkey
Steering
He did quiz me on my usernameCapa wrote: ↑Mon May 20, 2019 1:55 pmSolidly amused by this. But good on you for having a look at it in the end!wonkydonkey wrote: ↑Sat Apr 13, 2019 6:28 pm firebobby I haven't heard from him - unsurprising really when a stranger calling himself wonkydonkey offers to look at your wayward steering
Previous:
<My name is James>
<My name is James>
- davros
Steering
Just want to pass on my thanks to wonkydonkey and everyone who's contributed to this thread and this one: viewtopic.php?f=3&t=100725.
The information provided has been invaluable and after many painful hours (it seemed like hours) squeezed deep within my foot-well I've finally managed to adjust the ring 5mm clockwise and my zed has transformed into another car
3.0i E85 Sterling Grey, Infinitas supercharger, Aero sills, xenons, pro hi-fi with dsp & nav, power fold mirrors. B12 kit, Eisenmann backbox, //M-Sport Seats, carbon dash, cruise and more mods in near future......
- wonkydonkey
Steering
Excellent news! Now you can enjoy the car the way it should be! Nice workdavros wrote: ↑Thu Jun 06, 2019 4:21 pm Just want to pass on my thanks to wonkydonkey and everyone who's contributed to this thread and this one: viewtopic.php?f=3&t=100725.
Previous:
<My name is James>
<My name is James>
Steering
To gain access did you have to remove both the ignition cowling and the lower cowling?
Just trying to save time ,did anything else get in the way?.many thanks Matt
Steering
The lower ignition cowl is a couple of screws, if I remember rightly. Your best to get both cowls out of the way, then lower the steering column as far as it will go. Move the seat back as far as poss too.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- wonkydonkey
Steering
I've never removed the ignition cowling. Perhaps take off the lower cowling first (three Philips-head screws) and then decide if you think you need to remove the ignition cowling. It certainly isn't necessary, but I can't picture if it would help. It may do?Matt Robbins wrote: ↑Thu Jul 18, 2019 6:43 pm To gain access did you have to remove both the ignition cowling and the lower cowling?
As firebobby said, lower the wheel, but also pull it all the way out.
Previous:
<My name is James>
<My name is James>
