Oil Leak
- Chris_D
Oil Leak
HAve you looked around the oil filter housing gasket to check for leaks there?
I had to replace cam cover gasket as well as the ofh gasket. (note, not the rubber ring where the oil filtersits but where the front end of the block mates with the oil filter. get a torch in there and look for signs of leakage on the honeycomb structure on the passenger side of your engine.
If it isn't this then it could be worst case scenario, as jl-c suggests - your main engine-gearbox seal.
And yes, those belts also look way past their best.
Could also be your sump gasket but I doubt it due to oil still originating possibly at the top end of the engine.
Are you measuring oil-loss. If significant then it could be worth a visit to an indy....
good luck
good luck
- patriot66
Oil Leak
I agree with Chris_D. Take a long hard look at the Oil Filter Housing gasket. First of all you need to clean up to properly see what's leaking. Get some Gunk degreaser, spray on, brush in, hose off and blow it dry with an air line if you have one.
The alternator is mounted on a very elaborate cast bracket that is also the Oil Filter Housing It bolts on here, where all the oil is running from I'm fairly sure all this mess in your photo is coming from this gasket I replaced mine last year and it's an hour job tops to remove the alternator and bracket and fit a new gasket, and you can replace that shot-at serpentine belt at the same time
Oil Leak
Oil filter housing gasket and front crank seal as a good guess.
Oil Leak
Latest update: I changed the oil filter housing seal and the drive belt over the weekend. It was a nightmare getting the new drive belt on as the tensioning cog was extremely tight/stiff and didn't want to move. I eventually got it on with the help of a wooden hammer handle and a piece of rope (don't ask!). I really don't want to have to do that again
I noticed that the bolt which attaches the vanos unit oil line to the oil filter housing had only one washer on it instead of two. Was I supposed to replace the washers with new ones? I didn't have any so I had to replace the bolt using just the original single washer. Hopefully it will be ok.
Changing the rocker cover gasket and ofh seal seems to have stopped most of the oil leaks. Annoyingly however there is still a small amount dripping from the metal protective cover plate, in the area to the back of the driver side front wheel. I think it's forward of the sump hatch so I'm hopeful it's not the engine/gearbox seal. What else could it be though? The sump gasket? Anything else?
I'll get her back on the axle stands this weekend, take a proper look and get some more pictures.
I just hope this ends soon!
David
David
- mr.tourette
Oil Leak
sump gasket could be possible.. mine has just recently given up and been replaced.. apparently bmw use old recycled sweetie wrappers or something of the ilk for gasket materials as ive now done the oil flter housing, rocker cover and sump over the last 4 years
