Newbie to Z4, boggy and surging acceleration
I had the same thing, used a cheep ebay special and it was great for a while but it's starting to have the classic rough idle
Well, fast running out of patience with the dealer, took it in Wednesday, gave them a print out of the fault codes, told them I thought maybe valvetronic motor. Today he tells me he still doesn’t know what’s wrong with it, he has ordered a new valvetronic....I asked did he mean the motor....er yeah but to be honest if that doesn’t fix it then he feels he is out of his depth!!!
Great, not sure what to do now, had it less than two weeks, love the car but I’m now worried it isn’t going to be sorted right
- tug
GET OUT OF THERE FAST AND DONT PASS A PENNY OVER. He obviously knows very little He doesn't know BMW and to fit a valvatronic you need a certain amount of knowledge. The engine 'fits it' by the mechanic knowing where to place the motor and using ignition control. Damage can be caused if not fitted professionally.
Hope my advice helps buddy.
Cheers, tug
Cheers, tug
E85 N46 2.0i SE BLACK SAPPHIRE
Well today I finally got my Z4 back and touch wood it all seems to be fixed. It has been nearly three weeks since handing it back with the issues it had, very long story short they tried cleaning various sensors, that fix it, they ordered a new valvetronic motor, this took a week to come and then was the wrong part, so they ordered the correct one after I gave them the part number, this took another week to arrive, they then fitted it and the car wouldn’t start (yes they did program it first) turns out the new part had been damaged in transit and was bent....I was then told that they are rarer than rocking horse poo and even BMW has a wait if one month to get one....so I rang BMW and they got one the following morning. This then got fitted all seemed hunky dorey they delivered it back to me, I drove it and the surge was gone, parked it on my drive and checked for fault codes of which there were quite a few, valvetronic adjustments, some plausibility ones and others I can’t remember, the delivery guy/ mechanic was still with me so we cleared the codes and surprise surprise it then wouldn’t start. So off it went back to the garage, I said that I thought it was the eccentric shaft sensor as that was common to all the codes bearing in mind the motor is a genuine BMW brand spanker. The following day the garage said they had taken it to BMW and had been advised to check the eccentric shaft sensor for oil, This turned out to be the culprit, so a shiny new sensor from BMW now fitted and all seems good, no surging on acceleration, no bogging down and a rock solid steady idle. So in summary I believe both parts were at fault, costly parts too, luckily I didn’t have to pay a penny
Very lucky and a great outcome
Was feeling very unlucky for weeks, almost gave up on the Z4 completely
- ph001
Oil contamination on the eccentric shaft sensor should have been the first thing they checked rather than the last. It was mentioned quite early on. Good to hear you are back in the road though.
- Hebbs
Told I need mine replacing by my mechanic and said to see if I can locate one cheaper than he could get. Any links to where to get one would be appreciated.
