Indicators
Indicators
There is a resistor in the box at the bottom, you'll need to put a multimeter across it. Unless there is a break in the circuit I can't think of any other reason. Is it both sides that double flash when using the stalk or just one side?
The only other way I can think to check would be to turn off the bulb checks and see if that cures it. Would also solve the MOT issue, though if they flash at between 60 and 120 per minute and there is no dash warning on then they should pass, and even a Minor isn't a fail:
4.4.4 Flashing frequency
Indicators must flash at between 60 and 120 times per minute. Semaphore type direction indicators don't need to flash.
Defect
Category
Rate of flashing not between 60 and 120 times per minute
Minor
Defect
Category
Minor
- Kev
Indicators
Yes both side double flash from stalk, i would say these are over the 120!
Where do i turn off bulb checks?
Z4 Project - RSV4 Track Bike - Yamaha TRX850 Cafe Racer - Ducati project
Indicators
Either way, shouldn't be a fail.
Need Carly or NCS expert to code out
- Kev
Indicators
Have carly no faults showing but bulb light lit on dashboard, over 120 is a fail but that aside i dont like them like that so need to get them sorted somehow.
Indicators
As I've quoted, a minor defect is not a fail.
So the car is detecting an indicator bulb fault (you've said on both sides). Not used Carly but there will be the option to turn off front indicator checks, I just can't say how.
- mac27040
Indicators
offers still open to code your car! i have carly and navcoder
3.0i SMG Supercharged,19" CSL, AvinUSA android 10.25” screen,DSP,M6 gearknob,Coilovers,Aero F-bumper,M r-bumper,Aero skirts,Facelift front & rear lights,M sports seats,Carbon Steering wheel,Intravee,Rervese cam,Hydrographics
- Kev
Indicators
I do appreciate the offer and i may well take you up on it yet
- Kev
Indicators
Just thought i've took front foglights off would that bring up a bulb warning?
- mac27040
Indicators
probably
- mac27040
Indicators
again you can code that out
Indicators
Front fogs are not monitored.
