HELP! Oil leak
GixerWill
HELP! Oil leak
Post by GixerWill » Fri Mar 08, 2019 3:43 pm
Hi guys
I have just purchased a 2006 Z4 E85 2.5 Si Sport.
On returning home I could smell oil which prompted me to check under the bonnet, where I discovered what can be seen in the below picture.
The car failed it's MOT on Monday due to an oil leak, but the previous owner assured me it was a leaking oil filter seal, which was replaced. I believed him as later that same day it passed it's MOT with no advisories.
Does anyone know by looking at those pictures where the oil might be coming from? I'd like to fix it myself if possible, or at least know what I'm dealing with before a trip to a local BMW specialist.
I have uploaded a quick 13 second video. The noise in the background is the rain, it was pouring it down.
[youtube]https://youtu.be/khk-m2LP2cQ[/youtube]
Thanks in advance
Will
Webp.net-compress-image (1).jpg (224.68 KiB) Viewed 1156 times
wonkydonkey
HELP! Oil leak
Post by wonkydonkey » Fri Mar 08, 2019 4:37 pm
Whip the plastic engine cover off for a closer look :)
Previous:
~2006 Z4MR in Silver Grey
~2003 3.0i E85 in Sterling Grey
Click here for the Sticky Steering thread
<My name is James>
mr.tourette
HELP! Oil leak
Post by mr.tourette » Fri Mar 08, 2019 5:19 pm
there is oil on the rocker cover gasket for sure... thats not to say its not come from elsewhere, clean as much up as possible with brake cleaner and you may then find the source after a run out
GixerWill
HELP! Oil leak
Post by GixerWill » Fri Mar 08, 2019 8:51 pm
Thanks guys, will do.
Since taking the pictures I have booked it in with a BMW specialist to be seen on Tuesday. They have quoted £65 for a BMW gasket and around £80 labour. Seems quite reasonable.
ben g
HELP! Oil leak
Post by ben g » Fri Mar 08, 2019 10:00 pm
It's more than likely the rocker cover gasket. That area is exactly the same place mine began to leak from (older M54 3.0 engine).
That price from BMW seems very reasonable. It's not a difficult job, it's just a bit messy and if you don't like standing outside messing around with cars, then its worth letting them deal with it :thumbsup:
wonkydonkey
HELP! Oil leak
Post by wonkydonkey » Fri Mar 08, 2019 10:12 pm
There is oil coming from above though, unless I'm mistaken. This means that there is at least one leak source that's above the valve cover/cam cover gasket. It also means that oil may not be leaking from the valve cover gasket at all.
I replaced my valve cover gasket last week. £27 for a decent (Elring) kit including the additional rubbers.
Previous:
<My name is James>
wonkydonkey
HELP! Oil leak
Post by wonkydonkey » Fri Mar 08, 2019 10:13 pm
ben g wrote: Fri Mar 08, 2019 10:00 pm That price from BMW seems very reasonable.
BMW specialist :wink: BMW would surely want at least a grand for this? :rofl:
Previous:
<My name is James>
Lance
HELP! Oil leak
Post by Lance » Sat Mar 09, 2019 11:00 am
I'm not with my car at the moment, so can't check, however I changed my rocker cover gasket late last year and I'm sure there's a few small wells above the gasket that gather oil which then runs down. Mines an E85 though, so may be slightly different.
I'm pretty sure a new rocker cover gasket will solve the leak!
ben g
HELP! Oil leak
Post by ben g » Sat Mar 09, 2019 11:46 am
wonkydonkey wrote: Fri Mar 08, 2019 10:13 pm
That's what I get for reading whilst tired :lol: I did think it was extremely cheap for a dealer :oops:
wonkydonkey
HELP! Oil leak
Post by wonkydonkey » Sat Mar 09, 2019 12:02 pm
Lance wrote: Sat Mar 09, 2019 11:00 am I'm pretty sure a new rocker cover gasket will solve the leak!
The cam cover gasket sits below the apparent source of the leak though, so it wouldn't be my first suspect in this case. Just trying to save any wasted time/money for the OP :)
Previous:
<My name is James>
Migizi
HELP! Oil leak
Post by Migizi » Sat Mar 09, 2019 1:25 pm
since the oil leak appears to be coming from ABOVE the valve cover gasket...
Here's my guess/suggestion
1st you need to remove that silver/grey cover (ignition coil cover)
then you will see and can check the seal/gasket for the camshaft adjusting actuator which is also known as the Variable Timing Unit as well as Eccentric Shaft Actuator... it is mounted at the top center of the camshaft cover
variable timing unit.jpg (87.8 KiB) Viewed 1004 times
Very Easy gasket to replace and very inexpensive.
2006 BMW Z4 3.0si
wonkydonkey
HELP! Oil leak
Post by wonkydonkey » Sat Mar 09, 2019 2:20 pm
Migizi that sounds wholly plausible to me, and much faster/cheaper :thumbsup:
Previous:
<My name is James>
GixerWill
HELP! Oil leak
Post by GixerWill » Mon Mar 11, 2019 6:03 pm
Thanks so much for all of your input, unfortunately it has been snowing here so I haven't had much of a chance to have a look. The car is booked in with the BMW Specialist tomorrow. So hopefully it may be the cheaper of the two gaskets.
Although, do you think if it's the original rocker cover gasket which is on the car it might make sense to have it replaced as some preventive maintenance? Maybe the rocker cover and the Variable Timing Unit gasket (thanks Migizi) and on further inspection perhaps the oil filter seal :headbang: (see new pic)?
Z4 oil filter.jpg (235.76 KiB) Viewed 936 times
Z43.0Si
HELP! Oil leak
Post by Z43.0Si » Mon Mar 11, 2019 10:36 pm
Looking at your last picture, that looks very much like it’s the seal between the heat exchanger and the oil filter housing. I’ve replaced this on mine recently and I believe it’s a common area to leak oil.
You may find that’s the source of your leak and the oil is migrating. There’s always the possibility that there is more than one source to the leak :cry:
GixerWill
HELP! Oil leak
Post by GixerWill » Tue Mar 12, 2019 12:46 pm
You may be spot on there Z43.0Si . It's currently with the BMW specialist, I will report back his findings. He's also checking the brakes as I was getting some steering wheel judder when braking at higher speeds. Hopefully today won't be too costly.
