Hi chaps
Has anyone got any tips to move these nuts as they stuck and I tried for hours to move them. I left wd40 over night and no luck.
Thanks for your help in advance.
Windscreen arm nuts wont move
- Vbstein
BMW Z4 3.0I is old but not obsolete.
Give them a tap all the way round the nut a few times with a hammer Vbstein. Also you can strike the bolt head a couple of times square on, not too many as you don’t want to damage the threads but it’ll stand a couple of decent hits. Hopefully you’re using a socket to take them off. Failing the hammer taps you’ll probably need to borrow an impact socket from somebody if they still won’t budge.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- road warrior
Try releasing fluid, and then if you have a little blow torch to WARM it, it will be better than using brute force
If you ever think I'm off my rocker.. Just put me back in it and walk away... It's the kindest thing
My wife says I never listen - or something like that.
gone but not forgotton -Mean Steve - made a sound like a bear with his nuts in a trap.
- ph001
Thermal shock is the way to do it. Loctite Freeze and Release...
https://www.ebay.co.uk/itm/Loctite-8040 ... .l4275.c10
...then apply heat with a jet cigarette lighter (blowlamp is too big and clumsy in that area).
https://www.ebay.co.uk/itm/PROF-Angled- ... rk:65:pf:0
Do the heat / freeze cycle a few times. They will come off no problem. The of course you have to pull the arms off the spindles! Again, buy a proper tool - don't cost much and makes your life so much easier....
https://www.ebay.co.uk/itm/Battery-Term ... xypNtSj6Y7
