Strange engine bay noise??
- Marlon
Does this sound like the headlight self levelling motor?
It only makes this sound when lights are turned on.
direct link:https://youtu.be/_5T3z0TShQs
Gone: 3.0si 2008 E85
911 997 Carrera S
- Chris_D
Have you checked for stray cats trying to keep warm by crawling up into the engine bay overnight?
This one sounds like he's playing around with a drum machine, and if I'm not mistaken it sounds like a Roland TB303.
- Marlon
Cheers Chris! so a saucer of milk then
911 997 Carrera S
Sounds like the cash machine the one you will need to sort it out
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
get some one to sit in car and turn the headlights on, they should go up then down and level out, if one side isnt then yes motors at fault, or
you can tell yourself at night with car facing a wall
- Marlon
Thanks biojo, I went out tonight and noise gone and lights auto levelling as they should
I was going to take it to the local Indy to let them hear the racket but will now wait and see if it comes back
911 997 Carrera S
- Smartbear
Did it start making the noise after you had work carried out on the headlight washer? Seems a bit of a coincidence if that’s the case?
e85 3.0si sold
- Marlon
Not looked at the washer issue yet Rob. I did however remove fuse 40 to disable the headlight washers as you and others suggested in my other thread. But, this issue seems unrelated as I had the noise before and after I removed the fuse.
911 997 Carrera S
- Chris_D
You know you can change the interval, duration and stop it completely via carly?Marlon wrote: ↑Sun Feb 24, 2019 9:51 pmNot looked at the washer issue yet Rob. I did however remove fuse 40 to disable the headlight washers as you and others suggested in my other thread. But, this issue seems unrelated as I had the noise before and after I removed the fuse.
- Marlon
Didn't know Chris, haven't got carly - pulling a fuse seemed the simple solutionChris_D wrote: ↑Sun Feb 24, 2019 10:53 pmYou know you can change the interval, duration and stop it completely via carly?
911 997 Carrera S
