Hi again all, I managed to remove the hardtop from my 03 2.5 without any drama. I bought the car with the hardtop on so didn't test the soft top!! I now find that it won't raise!! The motor turns or makes a motor noise! I can lift the hood most of the way up and it then closes as it should. It won't go down either, once again the motor turns but nothing happens, I pull it back and then it engages and goes down the last bit.
If anyone can shed some light it would be appreciated
Regards Steve
Soft top will not raise
- Smartbear
Hi, make sure the red handle in the boot is seated properly-that disengages the motor from the hydraulic system .
e85 3.0si sold
Smartbear you are spot on... One fully functioning hood yippeeee
Thank you for your help
Steve
Steve
- Smartbear
Good news
e85 3.0si sold
