Good read.ph001 wrote: ↑Mon Feb 11, 2019 3:35 pm That's more than likely a wheel speed sensor. You need to read codes to find out which one if it's not obvious from a visual inspection.
This guide will show you everything you need to know...
https://www.pelicanparts.com/techarticl ... cement.htm
warning lights
- buzyg
warning lights
warning lights
Many thanks got it
- road warrior
warning lights
Clean the sensor
If you ever think I'm off my rocker.. Just put me back in it and walk away... It's the kindest thing
My wife says I never listen - or something like that.
gone but not forgotton -Mean Steve - made a sound like a bear with his nuts in a trap.
warning lights
Thanks very much for the Pelican link very good. I am looking to keep my zed for some time to come, and it looks like an error code/diagnostic reader is going to be very useful. Of the ones that you have listed is there one that in your experience would be the one that would be of the most use.
- ph001
warning lights
Depends on your level of IT skills. Software setup and driver conflicts can make the INPA type installs a bit troublesome, although the install packages have got a lot better than they used to be. Simple apps like Torque are OK if you are an android guy.Robert63 wrote: ↑Fri Feb 15, 2019 10:12 am Thanks very much for the Pelican link very good. I am looking to keep my zed for some time to come, and it looks like an error code/diagnostic reader is going to be very useful. Of the ones that you have listed is there one that in your experience would be the one that would be of the most use.
If you just want to clear engine fault codes and dabble with coding then Carly is tough to beat in terms of a user friendly interface. Just their recent silly subscription model is unattractive for most people from a price perspective. A lot of the aftermarket OBD2 dongles don't work with it so you are taking a gamble on not buying the recommended one that goes with the Carly package.
Scanners like the C110+ are a good compromise for most. They can usually interrogate a lot of the sub modules like airbags etc that other generic readers can't and are pretty intuitive to use. Can't do coding on them though.
warning lights
Hi of the error code readers that you have so kindly listed is there one in your experience that would be the most useful, many thanks for all your help.
