Prop shaft nock
lee1981
Prop shaft nock
Post by lee1981 » Fri Feb 08, 2019 2:56 pm
Afternoon all,
Just a quick question. I've the common clunck coming from what sounds like the gearbox/propshaft which is heard mainly when driving, not just changing gear at a standstill.
I've read somewhere in the past that it's quite a common noise with the grease on the propshaft? Specialised grease or something?
Wondering how much of a difficult job it is getting the propshaft off to do the work? I've had the exhaust off from the manifold back of late so shouldn't be too much hassle removing it which I'm guessing I will need too to gain access.
Any info would me much appreciated.
Cheers,
Lee.
Online
buzyg
Prop shaft nock
Post by buzyg » Fri Feb 08, 2019 3:24 pm
Doesn't sound common or right to me. :( Hopefully I have that wrong.
mjennings23
Prop shaft nock
Post by mjennings23 » Fri Feb 08, 2019 3:28 pm
Once the exhaust is off it's pretty much just the heatshield to remove I believe.
skelters
Prop shaft nock
Post by skelters » Fri Feb 08, 2019 3:58 pm
Heard of this happening in the past on some cars. Quite possibly the Flex Disc.....
Driveshaft clunking when pulling away. Flex disc and cs bearing shot?
viewtopic.php?t=97640
BMW Giubo Flex Disc + Driveshaft + Transmission Mounts Install DIY
2007 Z4 3.0si Sport. Silver Grey Metallic, Brembo Brakes, HEL Braided Brake Hoses, Machine Monkey Exhaust Tips, Stubby, Piano Black trim, Black Leather, Michelin Pilot Sport 4 on MV2's
JamieZ4C
Prop shaft nock
Post by JamieZ4C » Fri Feb 08, 2019 4:26 pm
I have this "clunk" and I'm fairly sure it is quite common.
If it's the guibo or 'donut' you would normally get a clunk when selecting first gear from neutral (and perhaps reverse too). Mine doesn't do this and I know the previous owner replaced the guibo.
I can get mine to make the clunk if I blip the accelerator whilst pootling along in first or second not much above idle. It's a metallic clink/clunk coming from directly beneath/behind me and I believe it is where the prop enters the diff and indeed it just needs regreasing. The grease is 83230417754.
Hoping to get mine done this year. A member on here (Markos_Z4) had the same issue fixed and advised me it probably wasn't worth trying to DIY and to just pay a garage to do it. Of course, very good advice which I'll probably ignore :lol:
The good news is I don't think much harm is being done, it just doesn't sound great. Hope that helps and good luck diagnosing and fixing your clunk :thumbsup:
Ewazix
Prop shaft nock
Post by Ewazix » Fri Feb 08, 2019 5:29 pm
An old thread worth reading :thumbsup:
viewtopic.php?f=3&t=97640&start=15
2018 Cooper S Countryman
Fiesta Ecoboost
Chris_D
Prop shaft nock
Post by Chris_D » Fri Feb 08, 2019 7:28 pm
Ive yet to conclude that thread with fix followup.
I'll be tackling it when the warmer weather hits.
Hasnt given me any issue or concern since and as others say it sounds worse than it is.
:roll:
Image Image Image
Now: E85 3.0iSE roadster (03) 'Bruiser'. E93 320d M-Sport Cabrio (11) 'Bob'.
Past: E36 323i (96) 'Benny' 18yrs/260k RIP. E46 M3coupe (03) 'Pongo' RIP. Ariel Atom 2(shared).
paddy wright
Prop shaft nock
Post by paddy wright » Fri Feb 08, 2019 8:59 pm
As said above it’s the prop shaft doughnut by the sounds of it.
MACK
Prop shaft nock
Post by MACK » Sat Feb 09, 2019 7:15 am
I had the propshaft clunk when I first got mine. I used the loctite grease/liquid metal on the splines and never had an issue since. However this sounds more like the doughnut is the issue, as the spines only really present when selecting first/reverse from stationary, not on the move.
Silver 05 3.0i SE
Mods- F/L Xenons 4 Spot Clear Rear Lights Clear 3rd Brake Light M Sport E/H Seats & MFSW 3M Carbon Wrap Dash Trims Parrot MKi9100 screen in ashtray Cruise MM Tips ZHP B4s and M Spec tyre sizes 3.64 DIFF
lee1981
Prop shaft nock
Post by lee1981 » Sat Feb 09, 2019 11:37 pm
That's brilliant,
Thanks for the replies guys. I'll look at doing the splines and the doughnut and order them next week.
Might as well so them both while I'm at it.
I'll update upon completion or if I find anything else that's causing the noise. Hopefully it's nothing to do with the gear box itself.
Cheers again,
Lee
