Hi all,
Got a coolant leak that is coming from this little feller. Is it the temp sensor on the thermostat? Is it a case of remove and replacing the o ring or something easy or is it a bit more involved?
Coolant leak
Coolant leak
- C4755C2F-57B7-45C5-A83C-760BB4F0E333.png (952.38 KiB) Viewed 332 times
- BD0D4016-2881-40BE-B93F-4D4788B9264E.jpeg (192.23 KiB) Viewed 332 times
- 1000rr
Coolant leak
Temp sensor.
Get an OEM one, really easy to fit in around 3 minutes.
Coolant leak
Thanks very much. Is there a good online supplier people recommend for parts?
- Z4 Gaz
Coolant leak
The green ones on ebay for the e46 fit iirc. Can't check easily as in the pub, sure someone else can comfirm.
E85 3.0i
