UPDATE FIXED.Vibrating left front brake after heavy breaking and very hot wheel?!
UPDATE - issue fixed, changed the caliper no more rubbing.
Thanks again all.
Hi people,
As my subject shows I've got a little problem.
Under heavy braking my front left wheel vibrates and gets hot.
I've checked the bearing - appears fine when hot and cold.
Brake pads - not worn unusually ( which seems odd).
Pretty sure the disc is fine due to when it's cold everything spins lovely.
If I stop and wait 5 minutes and then drive the wheel seems fine again then after a few minutes it happens again.
I'm thinking it's a caliper issue or my disc is warping when hot and then upon being cold is fine. (Unusual as you would still expect a slight warp.)
Wondering if any one else has any other ideas or know of any known issues that could be the cause?
Thanks for reading and thanks in advance.
Regards,
Lee.
Thanks again all.
Hi people,
Regards,
Lee.
I'd go with a warped disc
- -Tom-
Iād be leaning towards a sticking calliper
-Z4 M Coupe, Silver Grey, Imola Red Nappa, carbon leather, CSLs, SuperSprint Race, Track Mode Enabled
-Tesla M3 LR
Previous - 3.0 si sport roadster, Silver Grey with Oregon Pearl Grey leather, Piano black, EIbach Pro, Stubby
-Tesla M3 LR
- buzyg
- shuey
Snap! Had the same problem last week.
Left front caliper was sticking - I think its quite a commom issue... took it to a bmw specialist, the caliper needed lubricating and a clean, and it was all fixed. 45 squids. Tho they did say its probably a temporary fix, and might need a new caliper (90 quid ish)
M2 OG / Manual / Grey
Previous
Z4C Si Sport / Manual / Alpine White
350Z VQ35DE / Manual / Silver
Seat Leon Cupra MKII / Manual / Silver
Ford Puma 1.7
Rover 214 Si (I know!)
Previous
Ford Puma 1.7
- chrisgreen
100% sticky caliper. Ā£45 rebuild kit from big red and garage hours labour.
Might need new disc depending how long/bad its been
'04 E85 Z4 3.0 silver/black - daily driver - Sold
'02 E46 M3 PY/Kiwi
'05 E46 330d Touring - Silver Grey/Black
'02 E46 M3 PY/Kiwi
- paddy wright
Sticking caliper- has same thing on my last X5
- road warrior
Collapsed brake pipe..
The Hose Effect
An often-misdiagnosed cause of pull is a collapsed brake hose. The hose will look OK on the outside, but the inner liner will cause a restriction on the inside. A brake hose problem like this can take two forms. First, it can act like a restrictor in the line. Second, it can act like a check valve.
In the ācheck valveā situation, fluid will freely flow into the caliper, but will not return to the master cylinder. This can mimic a stuck piston, as the caliper will fail to fully release.
The Hose Effect
If you ever think I'm off my rocker.. Just put me back in it and walk away... It's the kindest thing
My wife says I never listen - or something like that.
gone but not forgotton -Mean Steve - made a sound like a bear with his nuts in a trap.
I would go with sticking caliper.
Montego blue 2006 BMW Z4 coupe 3.0si with black interior, ZHP, Whippy, 12mm front/16mm rear spacers on BBS 108's wrapped in Michelin PS4's. :driving:Brand new Pierburg water pump fitted at 101k after failure (should have done it at 100k)
- road warrior
Make my day... Flex Pipes will cost 15 quid each side, to find out
Iād go with sticking Caliper too. I got new discs and pads all round about 1 year / 9k miles ago, since then had both front callipers cause your symptoms on different occasions. Got brand new callipers fitted both times then come MOT time this week it fails due to āOffside Front Service brake excessively fluctuating (1.2.1 (e))ā I then have to get brand new front discs and pads again
Z4 Coupe, 58 plate, black, love it
Cheers people,
Got one or order. Will update if it fixes the issue. Cheers for clarification.
Regards,
Lee.
Regards,
Lee.
Sticking or faulty caliper
I had the same issue
It juddered when I applied the brakes 50+mph
I changed both front discs and pads
It started t9 happed again and I realised it was the caliper,
Purchased a new caliper and purchased again new discs and pads
As it happens the garage that changed the caliper Saudi the brake discs and pads were not needed
Itās all sorted now
Though I do have a set of Pagid front and rear discs and pads that I purchased off a forum member
So if anyone wants brand new boxed Pagid discs and pads for Z4 coupe? Ā£160
Itās all sorted now
BMW E36 Compact āDakar Yellowā (sold to make way for Z4 Coupe)
BMW E36 M3 Evo Vert (sold due to hit & run)
BMW E36 M3 Evo Vert (stolen written off)
BMW E36 M3 Evo Saloon (sold to buy Vert)
BMW E36 318is Coupe (sold to buy M3)
