Xeon Headlight went out !
Driving to work this morning my near side headlamp flickered a couple of times and went out, then a light came on in the instrument panel.
Is there a normal failure with these xeons, the actual lamp or supporting modules etc.
Can I check the lamp with a meter ?
57 Plate 3.0 Si Auto SilverGrey - Red Leather
E89 35iS Space Grey - Red Leather. SOLD
56 Plate 3.0 SI Manual - Black with Red Leather- Scorpion exhaust, BC coil overs SOLD
54 Plate 3.0 SE Auto - Silver with Red Leather. SOLD
- RustyZ4
Sound like a lamp failure, just replace the headlight Lamp, although it might pay to replace the pair, as they might be a slightly different colour if you do just the one
Z4 E85 3.0, gone but now with son
- MalNCH
I'd put the non-working one in the working side first to see if it is the lamp before you buy any replacements, then you'll know if it's the lamp or the ignitor.
2004 E85 3.0i, Titan Silver Metallic.
Sounds expensive thanks for the tips.
- MalNCH
You could also swap the igniters to rule out the control unit.
- RustyZ4
New lamps (bulbs) aren't expensive, I would go down that route first, change them over and if by chance that is not the problem, worst you have is spare lamps,
swap ignitors over , to rule them out
then swap bulb. Hopefully this works
if the top 2 hasnt worked probs the ballast filled with water, bumper off head, light unit out as its on under side
- MalNCH
Depends what you class as expensive, £80 for a half decent pair just to check if one doesn't work doesn't sound particularly cheap to me.
£190 per bulb from BMW
Without doubt the bulbs gone and the longer you leave it the more risk you run of damaging the ignition.
I recently had the same issue and was quoted £248.66 by the main dealer to supply and fit a replacement bulb - they wanted the bulb £191 to supply the bulb only.
The recommendation is to fit the Xenons in pairs so I bought the Osram Nightbreaker DS2 two bulb pack from Amazon for £76.
Fitting is a pain in the area and best done with wheel off but plenty of videos on YouTube if you look - hope you get it sorted
Sapphire Black 23i
Previously 7xZ3's, 5xE85's, 2xE86's & 3xE89's
Ignitors not ignition
Sapphire Black 23i
- RustyZ4
Bought two off ebay on my last car, £20, they are still working fine today, 5 years later
Thanks,
It work again this evening for a few minutes, was bluer in colour before going put again.
I have order from Amazon a pair of new bulbs, the Osram DS2 Laser, 200% brighter, as they weren't good anyway. Failing that the igniter after.
Remember doing normal bulbs on my old Z4, a faff with the wheel on.
New bulbs fitted problem fixed.... plus is a better brighter light, we’ll worth doing.
Next job fix my broken PDC
