Reversing lights / PDC not working
gurkin1234
Post by gurkin1234 » Sun Feb 03, 2019 10:24 pm
Hi all, anyone come across a case of reversing lights and parking sensors not working simultaneously? Checked bulbs and connections are all good. Could it be some sort of sensor that detects reverse gear, on the transmission, that is broken? Thanks!
Courageous
Post by Courageous » Sun Feb 03, 2019 10:33 pm
Yes there will be a switch on the gearbox but have you checked for a fuse?
Beatman
Post by Beatman » Sun Feb 03, 2019 10:40 pm
Before you start looking at gearbox switches. The switch activates a relay that operates the lights. It would pay to check this frist before you start under the car..
My Car- 2004 3.0se sterling grey, mv3s , satnav, heated seats, ZHP.
Beatman
Post by Beatman » Sun Feb 03, 2019 10:46 pm
Courageous wrote: Sun Feb 03, 2019 10:33 pm Yes there will be a switch on the gearbox but have you checked for a fuse?
Fuse 6.
Courageous
Post by Courageous » Sun Feb 03, 2019 10:53 pm
And the fuse is ok? Yes the relay would be the next obvious candidate.
Courageous
Post by Courageous » Sun Feb 03, 2019 10:54 pm
Sorry Beatman just realised it was you with the fuse 6 post.
Beatman
Post by Beatman » Sun Feb 03, 2019 11:00 pm
Courageous wrote: Sun Feb 03, 2019 10:54 pm Sorry Beatman just realised it was you with the fuse 6 post.
That's ok. Fingers crossed for the relay, as looking at the diagrams the switch could be awkward to get at.
Courageous
Post by Courageous » Sun Feb 03, 2019 11:18 pm
Indeed! :(
pcube
Post by pcube » Mon Feb 04, 2019 6:42 pm
I'm having this same problem as well and was about to buy a new reverse light switch. What is this relay you guys are referring to? Where is it located?
markplant
Post by markplant » Mon Feb 04, 2019 7:41 pm
You could also see if the sounder for the reverse beep has been disconnected, if it's never worked, as people unplug due a sensor faults, if it has been working then not likely to be this
gurkin1234
Post by gurkin1234 » Sun Feb 10, 2019 6:36 pm
Thanks all for your replies. Tested the fuse today and it’s not that, so I reckon the culprit is most likely the switch given both lights and sensor have stopped working.
Now to get it replaced!
pcube
Post by pcube » Mon Feb 11, 2019 4:05 pm
Just to share, there is no backup light relay for the M models despite what realoem says. There's a note that mentions it applies to vehicles with automatic transmissions but the M only comes in manual...
