Front suspension collapse ?
Debenham, 12miles from Ipswich.
bit far from me I have 2 front struts and springs oh well think the suplex route is a good bet for you good luck
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
What should i be paying for a spring compressor ?
No sure maybe £20 I would have thought
- Papa_Zee
If you can borrow a 2 ton jack, get it in position for the rear wheel or even in the rear jacking position near the diff, you can then support with wood, bricks or axle stands as applicable.
2 tons are affordable now so you need one anyway as no jack come with the Zeds am I right, anyone? GL!
E89 35is
Got a jack, apart from springs, spring compressors (have a Halfords socket set) what else am i likely to need ?
Stick your VIN number into an online BMW spec checker (AKA "VIN decoder") to confirm which suspension was fitted to the car from the factory.
Then put your VIN number into realoem.com and then find the front suspension section for an exploded parts diagram with part numbers of possible spring options.
08 Z4 3.0si Sport Coupe in Montego Blue
www.mdecoder.com should be able to get you the information you need. Sorry to see your spring snapped man.
I couldn't find one that worked, i did find a post on here that said all 2004 Z4 3.0 cars came with the mpsport springs as standard so ordered the Suplex front coil springs part:6248. Just checked your link and it does have the msport springs
- road warrior
phone up bmw give them your reg and they will tell you what suspension you have - if you visit them they will print it out the cars's spec sheet for you
If you ever think I'm off my rocker.. Just put me back in it and walk away... It's the kindest thing
My wife says I never listen - or something like that.
gone but not forgotton -Mean Steve - made a sound like a bear with his nuts in a trap.
If you can turn the spring in situ, look for 3 lightblue dabs of paint in a row on the spring. If you have these, they point to M sport springs.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Awesome, glad I could help.
https://www.mdecoder.com/decode/ls82186
Has the M Sport suspension from factory, so youll need to replace it with like for like. Suplex are highly regarded on here and infact I have them on my car too. Part number is 06248 for the 3.0 manual msport
Those are the ones i've ordered, just wish it would warm up a bit (or stay dry)
Be careful undoing the pinch bolt that holds the shock into the hub, have a habit of shearing off if undone with a big bar, you can do it slowly with a ring spanner and a mallet to shock the bolt loose then tighten then repeat a little at a time to avoid shearing off. Buy new bolts from bmw.
You will find it very hard with normal Halfords spring compressors, you really need the floor standing hydraulic ones to make it easy and safe. I just replaced my front shocks and springs and wouldn’t want to do it any other way.
Apart from that it’s an easy job.
