Startup issues
Startup issues
Hey guys, I have an issue in my e86 coupe where I go to start and sometimes it just rattles instead of starting or starts with a rattle which can be heard. Anyone experience this before? Any ideas what it could be? It usually starts fine when I turn it off and try again
The rattle is only on startup and goes away once the engine is on.
Startup issues
Mine sometimes revs quite hard on start-up causing a short rattle before the oil is up to pressure. Is there a way of controlling this behaviour? It only seems to happen in cold weather
Startup issues
Doesn't sound good, could be an air leak some where ? Not good for a cold engine to rev hard when cold.
On start up from cold, my Zed has a split second rattle and then settles to a purr.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Startup issues
Sounds like the starter motor is on it's way out.esafaeian wrote: ↑Fri Dec 28, 2018 7:35 am Hey guys, I have an issue in my e86 coupe where I go to start and sometimes it just rattles instead of starting or starts with a rattle which can be heard. Anyone experience this before? Any ideas what it could be? It usually starts fine when I turn it off and try again
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- R60BBA
Startup issues
+1 for starter motor buddy.
However use an INPA to check for codes first.
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
Startup issues
Thanks guys,
Is there a chance it could be the ignition switch? Or could it be the flywheel (I have auto trans)? If it is the starter is there a chance that it could mess up the flywheel if I don’t get it changed ASAP? Or can it wait for a while till I manage to save and buy the starter (if it’s on its way out then I’m not too fussed if the starter is further damaged, just don’t want the flywheel to get damaged)..
Also not sure if this is related but prior to this happening I also noticed at times that there would be a delayed start, ie., I would turn the key to the “on” position and it would take a second or so before starting instead of cranking instantly as I turn the key.
Edit: is the starter hard to change diy? I’ve done quite a few things before on old cars (oil changes, thermostat, coolant shocks etc)
Startup issues
Never done one on a zed, other on here have though. I think they are a bit tricky but doable for a man of your caliber
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Startup issues
changed my starter motor a few months ago. A fairly simple job once you have taken off the air filter box.
Startup issues
Hithere, I have been experiencing similar issues on my M coupe, sometimes like you i turn the key and nothing happens or sometimes it is perfectly normal. Sometimes i hear a click and sometimes nothing. Is yours a daily driver or is it like mine and sits for 3 or 4 weeks unstarted and undriven ? I did 900 miles only last year and things seem to play up when not driven.
Still dont know if it is the starter as havent removed or tested as some on here suggested ignition switch as a pos cause. I have found an oe starter for £165.00 so will probably change to eliminate that. People have suggested to get a s/h ignition switch from a breaker but that goes against my nature as I would worry that that too could have issues due to being old and used. I havent priced a new one , it may be that they are not available or hiddeously expensive and that is why people go the used route. Any advice welcome. Good luck with yours and whoever fixes it first will hopefully post and help the other one sort theirs .
Startup issues
Hey guys, I've embedded a video showing what happens sometimes when I try to start the car. This is intermittent and usually when car has sat for a while (at least 10 or so mins), but I'm really concerned it could be the flywheel (have an auto so flexplate?)... The only thing which makes me think it's not the flywheel is when I drive the car a bit and then turn it off I can restart it multiple times (I think I've tried like 10 times in a row) with the car starting fine, it's only when the car has sat for a few mins. I'm really hoping it's just the starter motor but if it is the flexplate does anyone know how much it would roughly be to replace?
https://www.facebook.com/erfan.safaeian ... 687591204/
- SeanConnor
Startup issues
Mine has been doing this for as long as I have had the car (four years). I have replacedmad4slalom wrote: ↑Fri Dec 28, 2018 8:26 pm Hithere, I have been experiencing similar issues on my M coupe, sometimes like you i turn the key and nothing happens or sometimes it is perfectly normal. Sometimes i hear a click and sometimes nothing. Is yours a daily driver or is it like mine and sits for 3 or 4 weeks unstarted and undriven ? I did 900 miles only last year and things seem to play up when not driven.
The battery
The starter motor
The ignition switch.
It still does it now and again and nobody can tell me why. There are no stored error codes when this happens.
Last year I left it with an auto-electrician for three days and he couldn't get it to do this. I had the car back for a day
and guess what ? Click, lights, no crank.
I have just learned to live with it.
2008 Sport Coupe Automatic with lots of extras.
Now with cruise control and Mediabridge Gold wheels HAVE BEEN SACKED.
- R60BBA
Startup issues
esafaeian wrote: ↑Mon Jan 14, 2019 1:12 pm Hey guys, I've embedded a video showing what happens sometimes when I try to start the car. This is intermittent and usually when car has sat for a while (at least 10 or so mins), but I'm really concerned it could be the flywheel (have an auto so flexplate?)... The only thing which makes me think it's not the flywheel is when I drive the car a bit and then turn it off I can restart it multiple times (I think I've tried like 10 times in a row) with the car starting fine, it's only when the car has sat for a few mins. I'm really hoping it's just the starter motor but if it is the flexplate does anyone know how much it would roughly be to replace?
- CCF9CCD3-FD27-4883-88F8-D2BCBA616CF6.png (123.42 KiB) Viewed 917 times
- ph001
Startup issues
Any reason why you have used Facebook for your video instead of uploading to Youtube and linking to that??? Anyway, can't view it but be amazed if it wasn't your starter (starter solenoid to be exact). Can't see the flywheel being of any concern.
Startup issues
Whoops! Sorry guys, I've uploaded the video to youtube, please check it out below.
Thanks!
[youtube]https://www.youtube.com/watch?v=aE1YmcZRjrg[/youtube]
Thanks!
- R60BBA
Startup issues
Originally thought it was starter motor, however after watching your video I am starting to sway more to a faulty fuel pump...esafaeian wrote: ↑Mon Jan 14, 2019 11:44 pm Whoops! Sorry guys, I've uploaded the video to youtube, please check it out below.
Thanks!
