Boot (trunk) struts
- Trav
Boot (trunk) struts
Being USA inclusive in the title. My car had Stabilus lift struts fitted in the boot. They looked in reasonable condition. When I pop it from the keyfob I was expecting it to lift an inch. Or enough to get my fingers under. I ordered and fitted a set of Magneto Marellis, as I thought a different brand may give a bit of a different setting. They had quite some compression on them but exactly the same result. I dont want the Mrs fumbling about with her rings on when the boot only lifts about 1/4 inch at most. I dont want it opening like a clown car either.Any suggestions?
Z4MR A.W.
- cj10jeeper
Boot (trunk) struts
Can’t help for the US but there are many UK companies than can build any struts too any weight and speed. I’d do some Googling. I found one a few miles away that made me a set with stainless ends for less than OEM prices
Boot (trunk) struts
I had to read your post twice to understand what your asking.
When you open your trunk/boot with the remote, the top of the trunk/boot does not move. I think you are expecting it, when release to spring up a little. However, Z4's Trunk lids do not come up at all, they simply unlock.
At one time a Z4 aftermarket Trunk/Boot opening clip was being offered by at least one vendor. This basically clipped on to the bottom edge of the trunk/boot lid and after unlocking you would use it to lift the trunk/boot lid. I think it was being offer by "Z Solutions" out of California.
- GuidoK
Boot (trunk) struts
Doesn't the e89 have an adjustable bootlid stop buffer?
Boot (trunk) struts
I had it half right. The vendor is Roadster Solutions.....
www.roadstersolutions.com/page63.html
If you click on the above link and scroll down you'll see the listing for BMW z4 trunk lid handle. Although there is a picture of it, they no longer have it for sale. If your in the USA give them a call and perhaps they might be able to give you info on finding one of these.
- Trav
Boot (trunk) struts
Thanks for that. I had seen their website as they also still show soft top side covers. They no longer stock them either. The handle does protrude a bit in any case. I had a look online, it may be a case of buying adjustable gas struts. Or I might just have to live with it if it's just a feature of the car.Jas- USA wrote: ↑Thu Dec 20, 2018 12:49 am I had it half right. The vendor is Roadster Solutions.....
Z4MR A.W.
- road warrior
Boot (trunk) struts
Having replaced the struts on my 2.0 I of course find the same problem with Steve 3.0.
But here is the thing, given that the intention is to merely un lock and not open a LA tailgate stylee, does it actually matter if the strut is weak? Having replaced the 2 struts and now it has almost fierce resistance to shutting I'm wondering if there is any benefit at all - aside from building my muscles up to shut it ?
If you ever think I'm off my rocker.. Just put me back in it and walk away... It's the kindest thing
My wife says I never listen - or something like that.
gone but not forgotton -Mean Steve - made a sound like a bear with his nuts in a trap.
- tomrdy
Boot (trunk) struts
Not sure why some are saying it doesn't move at all - mine springs up enough to slide my fingers under the bottom lip.
Mine sprung up even when I had weak struts (my boot at any position that wasn't maximum open, would just fall/slam).
Now with new struts I need to put some grit in it to close lol.
But the unlock springing has not ever changed for me - remote open it interior boot button.
-SOLD- Nardo grey 2004 Z4 3.0i E85
-SOLD- 2016 Long Beach Blue M2 DCT
-Wishing- Z4MC Interlagos blue...
___
Australia
- srhutch
- Moderator
- paddy wright
Boot (trunk) struts
road warrior wrote: ↑Thu Dec 20, 2018 10:28 am Having replaced the struts on my 2.0 I of course find the same problem with Steve 3.0.
- paddy wright
Boot (trunk) struts
When the struts are weak and the boot slams you increase the risk of breaking the middle brake lightroad warrior wrote: ↑Thu Dec 20, 2018 10:28 am Having replaced the struts on my 2.0 I of course find the same problem with Steve 3.0.
- GuidoK
Boot (trunk) struts
Well if its an e85 its a dead easy problem isnt it?
Adjust the stop buffer or fit the new style stop buffer with the spring pins in it.
I could have sworn this was placed in the e89 section back then
- Jembo
Boot (trunk) struts
Ur lucky it’s not an E86 bootlid, weigh a ton
Lifer 54
Lifer 54
- road warrior
Boot (trunk) struts
debatable. cus if i had the money i would have
- Zulu4
Boot (trunk) struts
My E85 boot is heavy to lift with a boot spoiler.
2007 3.0si Auto Sport Roadster. Whippy.
Previous:
2003 3.0i SE Roadster. Whippy.
Previous:
