viewtopic.php?f=2&t=111409&p=1608611#p1608611thecremeegg wrote: ↑Fri Jan 04, 2019 11:21 pmIf you can find me a clear spot drivers side for sale then I'd happily do that, however hen's teeth seem more prevalent
Rear light cluster dim
- dhobbs
What’s the mating half of the connector like (the loom side)?
That must be rusty too.
3.0si roadster. Requisite stubby. Sound gen mod. LED numberplate lights. LED boot strip. Interior lights LED too. ZHP gearknob. Daily drive
Motor in boot. Bilstein B8 dampers. New radio, much better sounds
- thecremeegg
viewtopic.php?f=2&t=111409&p=1608611#p1608611Scooba_Steve wrote: ↑Fri Jan 04, 2019 11:32 pm
Dammit!!
- thecremeegg
- thecremeegg
So I've bit the bullet and just ordered a standard rear light as I need to use the car. I got the new connector wired up so just need the light.
I was however wondering if it's possible to split the rear lights and remove the lenses from the front, a bit like you do on the headlights? If so I could just transfer over my nicer lenses to the new backplate?
Would have thought they were glued together
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- srhutch
- Moderator
Should be able to with a dremel I would think.
