Smoke from engine compartment - any ideas?
Hi all - when I started my z4 ( 2.0) this morning I noticed a burning type smell and small amount of smoke coming from the engine bay - the area near the heat sheild - oily rather than plastic. The car had been sat over the weekend and I noticed it from cold almost as soon as I started her up. The smell/smoke lasted about 30seconds then stopped - i turned off the engine and started up again and no repeat. - checked oil and no issue nice and clear and electric gauge said level spot on, checked coolant and shows level fine- drove car to Mum and Dads about 45 mins each way and no repeat of issue - temp gauge fine and drove well without any problems no warning lights. No signs of any burnt wires/cables in engine bay- no sign of any leaks oil or otherwise- read a thread about oil leaks associated with the valve cover gasket but noticed the smell from cold so would not have thought that exhaust manifold would have been hot enough to burn anything off- just started her up again after being sat outside all afternoon and no issues- anyone got any ideas/experienced similar from cold? - I heard that the smog pump can also leak but cant see any signs of any oil etc . Could it be some crud from the road burning off?
E89 2.0 i S Drive M Sport
TT MK1 Roadster
RR Evoque
Now gone E85 2.0 SE
TT MK1 Roadster
RR Evoque
Now gone E85 2.0 SE
When I had this it was oil dripping on to the cat from the vacuum pump on the back of the head.
- Trav
Zeds dead... Sorry couldn't resist. I had something similar once (not in a Z) and found the culprit eventually to be a bit of plastic bag that got sucked up off the road. Just where the exhaust was still hot enough. Went away pretty quick though.
Z4MR A.W.
- Number5
It sounds like you may need to replace the rocker cover gasket.. It can develop a leak at the rear and then drips occasionslly on to the manifold. Gasket is about £30 from ECP and it takes about 90 mins to do.. There are videos on you tube .
Alternatively and sspilt oil around the filler cap will travel under the cover to the back and have the same effect.. Have you topped up the oil recently and possibly spilt any ?
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Cheers andyf1140 - where abouts is the vacuum pump so I can check to see if there is any signs of oil
TT MK1 Roadster
RR Evoque
Now gone E85 2.0 SE
TT MK1 Roadster
RR Evoque
Now gone E85 2.0 SE
Cheers Number 5 - gonna start checking for any oil around the valve cover after its left overnight - had a service about a month ago but would have thought any spilt oil would have burnt off by nowNumber5 wrote: ↑Sun Dec 02, 2018 8:33 pm It sounds like you may need to replace the rocker cover gasket.. It can develop a leak at the rear and then drips occasionslly on to the manifold. Gasket is about £30 from ECP and it takes about 90 mins to do.. There are videos on you tube .
TT MK1 Roadster
RR Evoque
Now gone E85 2.0 SE
TT MK1 Roadster
RR Evoque
Now gone E85 2.0 SE
Its at the back of the head on the left.
Hi Andyf1140 - thanks - turns out your sugestion was spot on - vacuum pump leaking - did you fix yourself or garage.? What sort of price is the repair.
TT MK1 Roadster
RR Evoque
Now gone E85 2.0 SE
TT MK1 Roadster
RR Evoque
Now gone E85 2.0 SE
I did mine you get the gasket from BMW it is a little round thing. Make sure you have the right thingy for the screw head or you could strip it,
and you may have to undo the heat shield or bend it a little to get your hand in.
- eleflo
I had the same, replaced the gasket and used a good sealant before putting back together, it did last a while but eventually I replace the pump. They do come up on Ebay.
wrong roof, 2 pots short, stubby, wrong exhaust, no heated seats, but I luuuuv it, Now all gone to a new home
It might be a sign that the ccv is bunged up a mechanic friend said that when it's not breathing properly it sucks the seal an wh8ch makes it leak
Cheers all - gonna get her booked into local indie as need rear pads and brake fluid also- hope its just the seal on the vacuum pump- been checking oil level and no change and no blue smoke from exhaust - also still has slight vacuum on the oil filler so hope the ccv is functioning ok -
TT MK1 Roadster
RR Evoque
Now gone E85 2.0 SE
TT MK1 Roadster
RR Evoque
Now gone E85 2.0 SE
Can you see if it's been replaced in the service history? Mine had done 97000 and hadn't been changed and the only symptoms were oil leaks and a rough idle. As soon as it was changed the idle smoothed out and the acceleration through the lower rev range was smoother as well. Only cost £120 for the part and an hours labor.
