Window not going up
- Nothgiel
Window not going up
I have an intermittent problem where the window does not always go up and seal instead it seems to sit away from the seal leaving a gap, do you have any ideas what this might be?
- philbo909
Window not going up
reset your window, iirc it's- ignition on, wind down window and hold down for further 3seconds, then wind up.
Sapphire black z4 coupe 135,000miles young
- srhutch
- Moderator
Window not going up
More than likely your window regulator is on the way out. Mine started playing up recently when in France. So I disconnected the motor before it totally failed. I could then open the door slightly before operating the roof. Will be my first job in the new year
- alane29
Window not going up
window regulator on the way out , is it clicking a bit going up or down ?
2007 E86 M Coupe
2005 E85 2.5SE
2005 E85 2.5SE
