BMW Z4 E85 Difference in Height of Rear Suspension With M-Sport
Nothgiel
Post by Nothgiel » Sun Oct 21, 2018 10:20 am
Hi
I recently changed my springs on my BMW Z4 3.0i because the left side was four centimetres higher than the right. The springs I used were identical Suplex 06231 springs for Cars with M Sport technology. The springs have now settled over a couple of weeks but I still have a height difference of 4 cm with the left side measuring 640mm and the right side 595mm with 18" alloys. the correct ride height should be 588mm +/-10mm so the left side is way out. Have you any ideas of why this might be???? :?
33 00 Rear axle - ride height E85.jpg (187.11 KiB) Viewed 770 times
Nothgiel
Post by Nothgiel » Sun Oct 21, 2018 2:22 pm
The Suspension at the front is equal and if I remove the shock absorber from the wishbone the height is still the same :(
