Water leaking drivers side window
Hi
Just noticed water dripping from the rubber seal 1/2 way down the angled part of the window on to the door window switches. The seals although old don’t look bad. Wondered if there is any adjustment I can do to make the door close tighter to the seal, or any other advice appreciated. E85 2003 2.5i
Tilly
Tilly
- z4too4
2004 Z4 E85 2.2i SE, Black Sapphire, Heated Dream Red Leather, Cruise
Plus
- Android 7.1.2, Touch, Voice, Navi, GPS, 3G/4G, Rear Camera, Dashcam, DVD, FM, Aux, USB, WiFi, BT, Phone, OBD2
- Parking sensors
- Wind deflector
- Fitted rubber mats
- LED bulbs
Plus
- Parking sensors
- Wind deflector
- LED bulbs
- z4too4
Entered the the car last night during the heavy rain to remove the broken first aid box and sure enough on both sides, water entering into the footwells at the point indicated ....
- Borrowed pic!
- DSC_0866_zpsj7y5zbn_edit_1415025816881_zpsfn3l9r6z.jpg (50.26 KiB) Viewed 1990 times
Plus
- Parking sensors
- Wind deflector
- LED bulbs
Plus
- Parking sensors
- Wind deflector
- LED bulbs
- LittleZ4
Mine is doing the same, leaking from that exact same spot
3.0i Maldives blue, Coilovers, Bola B1's, Buckley06 Gear knob, Handbrake & Indicator badges, Backbox delete, CDV delete, cupra r splitter, RAM air filter, Bigger Brakes, M3 ARB, SMF.
- z4too4
Apparently it's either
* the internal door membrane ripped or not sealed properly, or
* the door seal damaged or not sealing fully, or
* something else
* something else
Plus
- Parking sensors
- Wind deflector
- LED bulbs
Plus
- Parking sensors
- Wind deflector
- LED bulbs
- RustyZ4
I would start with some gummy pflege to all the seals around the doors it will revive them and if the water is getting around the seal stop it
Z4 E85 3.0, gone but now with son
- z4too4
Thanks! I will get some ordered
It's also mentioned in this post, as is something about pulling up the seals.
viewtopic.php?t=63712
Plus
- Parking sensors
- Wind deflector
- LED bulbs
Plus
- Parking sensors
- Wind deflector
- LED bulbs
- z4too4
Which is the right Gummi Pflege?
- IMG_20180923_102804.jpg (51.16 KiB) Viewed 1976 times
Plus
- Parking sensors
- Wind deflector
- LED bulbs
Plus
- Parking sensors
- Wind deflector
- LED bulbs
- RustyZ4
The first one (purple) is the one I have, I have some autoglym rubber care which is also really good
- z4too4
Magic! Thanks
Plus
- Parking sensors
- Wind deflector
- LED bulbs
Plus
- Parking sensors
- Wind deflector
- LED bulbs
I had water in the footwell also. Turned out to be the old seal on the door membrane had become detached, letting water leak from behind the door card. The area in the corner as shown in the pic was probably the worst area to be dripping water in. I have changed the membrane. So far, ok.
- z4too4
Hi, did you need to change the membrane or just the goo?Jamturbo wrote: ↑Sun Sep 23, 2018 3:49 pm I had water in the footwell also. Turned out to be the old seal on the door membrane had become detached, letting water leak from behind the door card. The area in the corner as shown in the pic was probably the worst area to be dripping water in. I have changed the membrane. So far, ok.
Plus
- Parking sensors
- Wind deflector
- LED bulbs
Plus
- Parking sensors
- Wind deflector
- LED bulbs
- z4too4
Wow, the membrane is 45+ quid!!!
19 Sound insulation, door left 1 51487016655
19 Sound insulation, door right 1 51487016656
Plus
- Parking sensors
- Wind deflector
- LED bulbs
Plus
- Parking sensors
- Wind deflector
- LED bulbs
I changed the membrane as the old one had mastic which I couldn't remove without tearing. Yes, a bit expensive for what it is.
- z4too4
Following the advice given I picked up a coil of Butyl (Amazon) and some Gummi Pflege (eBay).
After removing the panel visual inspection of the membrane didn't offer much in the way of clues so I checked the windscreen roof drain by pouring some water out of a jug into it. You can see the water heading down straight toward the carpet. The rubber seals are are bit stiff so maybe more water is hitting the drain hole than should when it rains. Hopefully the Gummi Pflege will soften up the rubber and improve the seal plus I'll add extra Butyl to the sound barrier membrane.
Plus
- Parking sensors
- Wind deflector
- LED bulbs
Plus
- Parking sensors
- Wind deflector
- LED bulbs
