2005 z4 i2.5 here...
Passanger side window operates normally with the switch on the passanger side as it opens and closes fully.
BUT! The switch that controls the passanger window ON THE DRIVER SIDE will only close the passanger window and not open the damn window...
Please help!
Passanger window issue...help....
- z4too4
Hi, Switch needs cleaning, wiring corroded or damaged, or switch is broken (one direction)?
Maybe trace the wiring and get a multimeter on it.
2004 Z4 E85 2.2i SE, Black Sapphire, Heated Dream Red Leather, Cruise
Plus
- Android 7.1.2, Touch, Voice, Navi, GPS, 3G/4G, Rear Camera, Dashcam, DVD, FM, Aux, USB, WiFi, BT, Phone, OBD2
- Parking sensors
- Wind deflector
- Fitted rubber mats
- LED bulbs
Plus
- Parking sensors
- Wind deflector
- LED bulbs
Its weird because the window closes whether I pull up or down the switch...passanger window closes either way....is something wrong with the wiring?
- z4too4
Maybe the wiring, maybe the driver switch, maybe even a fuse... As I have never had the actual problem I am summising based on on the fact the the signal to operate the door is sent from the switch through the wire, through a fuse, through a do hickey magic signal decoder box thingy to the window motor... Maybe
Plus
- Parking sensors
- Wind deflector
- LED bulbs
Plus
- Parking sensors
- Wind deflector
- LED bulbs
Mine was the same - I had to do the reset procedure on both drivers door switches at the same time. Odd I know but it didn't reset when I did it on just the passenger side. HTH
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
so do the reset procedure for the driver side switches (2) at the same time? Problem with this is that driver side switch that controls the passenger window does not open only closes so how do I do the reset procedure?...Simon 3.2M wrote: ↑Thu Sep 27, 2018 9:54 am Mine was the same - I had to do the reset procedure on both drivers door switches at the same time. Odd I know but it didn't reset when I did it on just the passenger side. HTH
I don't know then mate - try it on just the drivers and then both.
Sepang Coupe
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
