OK...this one's a bit odd. My external temp. sensor has gone squiffy and seems to have taken the roof with it.
When the car is started from cold, the temp sensor reads anything from -30 to -25c...and the roof does't work - no lights, red, yellow flashing or otherwise. No other warning signals of any description...car drives fine as is perfectly happy otherwise.
I initially thought it might be famous wet motor syndrome, but having driven around a bit, the outside temp rises and as soon as it get's to -9c the roof works fine.
Thought I'd see if anyone had any experience of this type of situation before I start dismantling things...
Any ideas?
Tim.
Outside Temp sensor says -25c...roof does't work. Drive around a bit, temp rises and roof fine. Any ideas?
- Keet
I'm sure that the e89 top won't operate below a certain temperature, so I'm guessing it's the same for the e85. So if the temperature is reading as low as you say then maybe that's the cause.
Keith
Alpine White, 2014 e89 20i M Sport (It's my wife's really )
yeah...doing some research - seems like the sensor's failed. Probably need to replace it.
reset sensor by the disconnecting battery, leaving it 10 mins, then plugging it back in. Sorted.
- road warrior
well done that man !
If you ever think I'm off my rocker.. Just put me back in it and walk away... It's the kindest thing
My wife says I never listen - or something like that.
gone but not forgotton -Mean Steve - made a sound like a bear with his nuts in a trap.
- road warrior
