Rear springs again
brack1e
Rear springs again
Post by brack1e » Thu Aug 09, 2018 12:26 pm
Having changed my broken rear springs 3 years ago today I found that the off side rear spring has again snapped after 8000 miles, I can't remember what make of springs were fitted but they weren't genuine BMW parts, my question is which springs should I buy having been quoted £280 from my local BMW dealer ( not fitted ) for two rear spring for my 2008 2.0l sport Zed, I don't really want to go lower or find the ride is harsher. Any advice would be greatly appreciated
mr nurburgring
Rear springs again
Post by mr nurburgring » Thu Aug 09, 2018 3:57 pm
I put KYB SPRINGS on 7 years ago and they haven’t broken yet.
philbo909
Rear springs again
Post by philbo909 » Thu Aug 09, 2018 4:01 pm
brack1e wrote: Thu Aug 09, 2018 12:26 pm Having changed my broken rear springs 3 years ago today I found that the off side rear spring has again snapped after 8000 miles, I can't remember what make of springs were fitted but they weren't genuine BMW parts, my question is which springs should I buy having been quoted £280 from my local BMW dealer ( not fitted ) for two rear spring for my 2008 2.0l sport Zed, I don't really want to go lower or find the ride is harsher. Any advice would be greatly appreciated
Personally I use suplex, you can get them £100 for a pair roughly I think,
https://m.ebay.co.uk/itm/SUPLEX-06231-R ... r=1&_rdt=1
Sapphire black z4 coupe 135,000miles young
brack1e
Rear springs again
Post by brack1e » Thu Aug 09, 2018 10:14 pm
Thanks for the couple of replies, I did look at Suplex but wasn't sure which ones I needed but I might have to make Some more inquiries, and if anyone else would like to recommend a good spring then like I said, it will be very much appreciated
highway1
Rear springs again
Post by highway1 » Fri Aug 10, 2018 9:36 am
Go for the Suplex-they are quality springs that are MSport equivalent and also available for se spec. BMW springs are hugely overpriced and likely to break again before the Suplex springs.
andystone
Rear springs again
Post by andystone » Fri Sep 28, 2018 11:00 am
Hi all, sorry to jump onto your thread, but I’m looking at replacing my rear springs due to corrosion, and plan on using suplex, with new rubber mounts top and bottom. I am though a bit confused as to which ones to buy (I have a standard e85, 2.5).
Are these the ones? What does the 6227 number refer to as I note they are different and are my cause of confusion!
2005 e85 z4, 2.5
philbo909
Rear springs again
Post by philbo909 » Fri Sep 28, 2018 1:21 pm
andystone wrote: Fri Sep 28, 2018 11:00 am Hi all, sorry to jump onto your thread, but I’m looking at replacing my rear springs due to corrosion, and plan on using suplex, with new rubber mounts top and bottom. I am though a bit confused as to which ones to buy (I have a standard e85, 2.5).CCFA7274-D531-4A07-A085-CC24BB1060A9.png
Standard like SE?
andystone
Rear springs again
Post by andystone » Fri Sep 28, 2018 2:22 pm
philbo909 wrote: Fri Sep 28, 2018 1:21 pm
Standard like SE?
Yes and original shocks etc
2005 e85 z4, 2.5
philbo909
Rear springs again
Post by philbo909 » Fri Sep 28, 2018 4:05 pm
andystone wrote: Fri Sep 28, 2018 2:22 pm
Standard like SE?
https://www.ebay.co.uk/itm/SUPLEX-06228 ... 284c7837f1
