Key problem
Key problem
My main keys doesnt work i.e it is unable to start the car, it can lock/unlock the central locking but thats it, just a couple of days ago it was working fine. Im left with using secondary key which works perfectly, is there a way to sort this problem out and what exactly is wrong with the key?
Key problem
At a quess it could be the battery in the fob which charges itself when driving. I believe it is possible to open the key up and put a new rechargeable battery in. Others will probably know better.
Key problem
Surely if the battery was low/dead it wouldnt be able to unlock/lock the central locking and roof?
- srhutch
- Moderator
Key problem
Battery has no effect on starting the car. The immobiliser chip handles that part.
- Silverzedtom
Key problem
Sounds like time for a new key. I misplaced one of mine for 6 months and was told £120 by a local dealer. Others on here do them too. I was expecting them to be more expensive to be honest
E85 2.5si
F55 Cooper S
F55 Cooper S
Key problem
well, at least its an easy fix..Im surprised it would go at such low mileage..
- jabber
Key problem
May not need a new key try putting the key on a tooth brush charger overnight then the is a resync procedure that you can do which may sort it here’s a link to how to do it
https://www.youcanic.com/bmw/key-progra ... -procedure
It’s worth a try first
Z less again
- Fox889
Key problem
Time for a new 'flip style' key fob from Mike "ooop North" perhaps?
2004 3.0 Z4 in Sterling grey metallic
- Mr Tidy
Key problem
Mike is on here as "ducklakeview" but you can also find him on Facebook as the Zed Shed.
He's based in Cheshire now I think - cut and coded a Bentley-style flip key for me last year, and it's great!
Or you could go the ZedFest as he will be doing keys and relocating motors there!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
