Can you point me in the general direction please?patriot66 wrote: ↑Thu Jul 19, 2018 9:44 pm If the 'budgie' is only chirping when the roof is down I'd bet it's the center catch/bracket on the hood. Mine used to drive me mad until I stuck a piece of self adhesive felt inside the central catch on the leading edge of the hood. Try placing a microfibre cloth over the small metal central bracket behind and between the head restraints. Lower the hood and go for a drive. If the chirping stops then get your self some felt !
Budgie? Where is it?
Onlinejock156
- srhutch
- Moderator
- patriot66
Unfortunately not got a photo and my Zed is at the panel-wackers until tomorrow. If you kneel on the drivers seat with the hood up and visually follow the centre of the cubby up and over the trim panel between the roll bars at the rear edge you should see a small, peculiar, black metal bracket. If you now stay in that position and lower the hood you will see that as it comes down to rest that a small plastic/metal mating piece comes to rest on the black metal bracket. The interface between the two is what squeaks like a budgie ! Resist the temptation to lube it or grease it as this WILL end up on your headlining. You can remove the bracket and receiver but I decided to leave well alone and got self adhesive felt and stuck a small piece in the channel of the receiver. Maybe someone could post some photos to clarify it for you ?jock156 wrote: ↑Fri Jul 20, 2018 2:29 pmCan you point me in the general direction please?patriot66 wrote: ↑Thu Jul 19, 2018 9:44 pm If the 'budgie' is only chirping when the roof is down I'd bet it's the center catch/bracket on the hood. Mine used to drive me mad until I stuck a piece of self adhesive felt inside the central catch on the leading edge of the hood. Try placing a microfibre cloth over the small metal central bracket behind and between the head restraints. Lower the hood and go for a drive. If the chirping stops then get your self some felt !
- Ewazix
For all things fecking annoying in the interior see here viewtopic.php?f=26&t=37362
(budgies get a mention)
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
Onlinejock156
Finally, finally let the Mrs drive yesterday and its deffo the catch as mentioned above.
Where do you buy self adhesive felt from though?
- Stuartt
B&Q they sell it in blister pacs to stick to the bottom or chair and table legs to stop them marking wooden floors etc
Stuart
2004 3.0i SE Roadster , GONE to a good home
2010 e89 35i Sdrive M sport. GONE for salvage but has been reborn
2014 e89 35is M-Sport Design Pure Traction
- Jembo
If the wife thinks the Budgie is in the boot, check your rear ARB drop links
Lifer 54
Lifer 54
- RickRob
Whatever it is I have the budgie's twin in our Discovery. It's driving me mad!
///M Roadster. 2007 Black/Black. Rear spoiler, whippy aerial, mud flaps and gimp-style wind deflector!
- Grumpyowl
