Car not cranking over
Just tried to start the z4 and it's not even cranking the starter motor. The lights turn on as normal but when I turn the key the starter motor doesn't even turn one bit.
The car is a e85 3.0, any help will be highly appreciated.
- R60BBA
Dead battery?
Used to own the above.
Now I drive an E46 M3 Coupe:
- Engine: S54B32
- Colour: Carbon Schwarz
Instagram: bavarianjunkie
https://youtu.be/y0ymv8jOC0Y
- RustyZ4
Sounds more like starter motor if the lights are all coming on etc, my sons 3.0 E85 did this the other week, and his wouldn't even crank tapping it with a hammer
Z4 E85 3.0, gone but now with son
I'd suspect starter too... low battery would try to start, tick and flicker all the lights on the instrument cluster.
you could try bump starting it if it's a manual, if it fires up easily it's almost certainly the starter.
Good luck
Good luck
E86 Coupe 3.0si Sport - Montego Blue, Pearl Grey with Piano Black dash
BC BR series Coilovers, powerflex bushes, 15mm spacers, Custom SS exhaust, CDV delete
I'd suspected it was, I've ordered a new Bosch unit. Hopefully that fixes it. Just been reading on here and it seems to be a very common problem as they go without much or any warning.
- DMC63
Starter motor? IF IT'S MANUAL Give it a bump as others have said. Mine went a few days ago. No warning, just silence when I turned the key
BMW Z4 2003 2.5i and lots of bits and pieces
Online
As above definitely starter motor mine went last week new bosch starter motor all sorted now
2004 z4 30i auto Toledo blue stubby areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod vanos overhaul 108s refurbed ram air scoop E46 M3 seats clear rear lights M/// sport black grills
Onlineadam04
Sounds like a starter motor issue, few threads around recently about people having issues. Theres a how-to thread on how to change it yourself and you can pick up a motor from Eurocarparts fairly reasonably.
2003 E85 3.0i Auto Titanium Silver / Aerobody Kit / Cruise / Xenons / Cupholders....
Ok, fitted a new starter motor and ignition switch didnt fix this, ended up being a faulty key..
