Really Rough Start- Motor shaking
2L8ULUZ
Post by 2L8ULUZ » Sun Jul 15, 2018 5:55 pm
Hello Gang,
Yesterday, I went to start my 03 E85 3.0 and the whole car started shaking with SEVERE misfiring...
I turned off the ignition, waited a few seconds and the re-started and all was fine....
No CEL- and again the car ran perfectly after restarting....
Recent Issues/Service: I just had the oil changed at an INDY in my area... Like 2 days prior to this...
Had a Fuel Pump wine about a month ago- thinking that this was bad gas... Ran a bottle techron and filled that tank with new fuel and it completely went away.
Changed spark plus 3 weeks ago... cleaned up slight missing at start-up with OEM's being in there at 94k miles…
The Z has only been driven 6k miles a year on average and was a retired persons toy... 2 owner
All service done at North Scottsdale BMW... Service history to best of my memory included a replacement spring, new drive belt, brakes and coolant flushed, brakes all 4 done at 30k and 75k.... basically the car was flawless and meticulous detail taken care of...
The car is an M-Sport Auto 3.0
95k miles
Can this be a fuel pump priming issue? Fuel Filter? at this mileage, I assume these wearable parts are starting to go?
Oil change, resulting in leaks in the air flow set up- checking filters etc.? This just happened 2 days after the oil change...
Really appreciate any input...
Lance
Post by Lance » Sun Jul 15, 2018 6:37 pm
The shaking is something mine did when a coil packed up. Car shuddered and mis-fired.
A trip to EuroCarParts and around. £20 later, all sorted.
That was getting on a year ago and no other failures since. I now keep a spare in the boot.
Note - I did experience a few bad starts before it finally packed up. Mine was similar mileage to yours when it failed
2L8ULUZ
Post by 2L8ULUZ » Mon Jul 16, 2018 5:26 pm
Thank you for the feedback....
How did you know what coil pack went out??
Lance
Post by Lance » Mon Jul 16, 2018 6:17 pm
https://www.amazon.co.uk/MAOZUA-Latest- ... nner&psc=1
I used one of those, I'm sure a bit of searching and you'll find them cheaper.
Other than that you could remove a coil lead at a time. A live coil lead removal will make the misfire worse. When you get to one that makes no change, that's the one :thumbsup:
Put up a location, someone nearby may have a reader and be able to assist.
2L8ULUZ
Post by 2L8ULUZ » Mon Jul 16, 2018 8:23 pm
A CEL will go off I assume if I let it just keep misfiring? that would tell me a cylinder
AveZ4coop
Post by AveZ4coop » Mon Jul 16, 2018 11:57 pm
I had this too. occasional lumpy running, gradually got worse over about two months, then engine fault light. Reset and all ok for a couple of days, then same again. I replaced all the coils (as if one is failing more are sure to follow) and plugs, no more problem. :driving:
Montego blue 2006 BMW Z4 coupe 3.0 with black interior, ZHP, stubby, 12mm front/16mm rear spacers on BBS 108's wrapped in Michelin PS4's. :driving:
