Random misfires on startup
JohnMRZ4
Post by JohnMRZ4 » Mon Jul 09, 2018 4:56 pm
Hi all, hoping you can help me diagnose a problem.
I started my z4 and it was running very roughly, I got P0300 and a warning light. The engine was physically shaking, so I took a look for anything obvious and found a hole in one of the hoses that runs from the air filter where the hose has perished over time. Looking from the front of the car to the rear, it's the hose that does goes left into the engine from the air filter housing. I decided not to drive it incase there's damage caused to the engine but I need to drive it to the garage for a fix and it's 40 miles away from where my car is at work. If there is a vacuum leak will it cause any damage? Has anyone else had this crop up?
Scooba_Steve
Post by Scooba_Steve » Mon Jul 09, 2018 6:00 pm
Put some tape over the hole to start with and try again? P0300 isn't specific just a misfire code, maybe INPA will give a better code. I assume it was a generic code reader?
ph001
Post by ph001 » Mon Jul 09, 2018 8:44 pm
You need a garage to change a hose?
2004 E46 M3 coupe manual.
Online
mr wilks
Post by mr wilks » Mon Jul 09, 2018 9:09 pm
Why is that so strange :? i would too :? but i could install a truss roof , construct a decent extension from scratch , screed & lay a karndean floor , convert a French barn etc all quite easily :wink: not everyone chooses to work on their own cars , i never have , perhaps i could but i don't .
E86
E85
///MR
Si E85
E89 23i
Si E85
E86
3.0Si E85
///MR
35i Msport 6spd
E86
///MR
E86
35is
911 997 Carrera4
https://www.instagram.com/andy911wheels/
JohnMRZ4
Post by JohnMRZ4 » Mon Jul 09, 2018 10:49 pm
It was a standard reader, I will get some tape and give it a go and see if it fixes it. The hose itself is quite tricky for a newbie like me to get to and change myself :?
JohnMRZ4
Post by JohnMRZ4 » Fri Jul 20, 2018 8:49 pm
Well, I taped up the hole but it didn't fix it. So I'm lost as to what it might be. I took a video of the engine featuring the noise it's making. Any ideas what it sounds like? The unusual sound is like a steam train - the chug chug chug
https://youtu.be/vDSYOSWPjWM
AveZ4coop
Post by AveZ4coop » Fri Jul 20, 2018 11:02 pm
doesn't sound good! Hope someone on here can help you and it's not too serious.
Montego blue 2006 BMW Z4 coupe 3.0si with black interior, ZHP, Whippy, 12mm front/16mm rear spacers on BBS 108's wrapped in Michelin PS4's. :driving:
Brand new Pierburg water pump fitted at 101k after failure :cry: (should have done it at 100k) :headbang:
Gazza51
Post by Gazza51 » Sat Jul 21, 2018 7:49 am
Sounds like a compression leak.
Z4 MC, M3 CSL, S54 Z3MR, Z1.
Fox889
Post by Fox889 » Sat Jul 21, 2018 11:43 am
I suppose my first question is, does she run ok after a few seconds or is she running rough all the while?
Sounds very much as if she's 'inhaling' far more air than she normally should?
I would take the air filter out, remove the air filter box & make sure all the hoses etc seem ok & go from there.
I know when I bought mine [3.0] carried out a full service then blow me, the yellow engine light came on, turned out to be the air filter box 'elbow' pipe had deteriorated badly.
Carry out the simple bits first then see where you are.
Just a thought........it wouldn't be something as stupid as a loose spark plug?
Tell us how you get on.
2004 3.0 Z4 in Sterling grey metallic
JohnMRZ4
Post by JohnMRZ4 » Sun Jul 22, 2018 10:32 pm
I have run the engine for a good minute or two and it keeps going as-is in the video with no signs of letting up.
Looking at the hoses I taped-up the bit where I could see an obvious rip, I didn't see any other splits.
The strange thing is it drove to work fine, then I came to go home and this started.
I guess other causes maybe valve cover gasket ? Bad coil packs probably wouldn't cause this sound?
AveZ4coop
Post by AveZ4coop » Mon Jul 23, 2018 3:14 pm
A bad coil pack/spark plug would cause a misfire and would first show itself under load. This doesn't sound ignition related.
JohnMRZ4
Post by JohnMRZ4 » Sat Jul 28, 2018 9:10 pm
Weirdly it was the coil pack on cylinder 2, replaced it and it is now running well, I didn't think it would be that simple. Thanks for all your help and replies
AveZ4coop
Post by AveZ4coop » Thu Aug 09, 2018 10:38 pm
Eating humble pie :oops:
Glad you got it sorted. :thumbsup:
