New Pierberg water pump - same as originally fitted ?
charlie8
Post by charlie8 » Wed Jun 13, 2018 6:44 pm
Hi
Can see these are the OEM parts to fit, however my question is, have these been modified from the original spec and so due to have the same lifetime as first installed ( which seems to be roughly 60K as a rough average ) or did the design improve via different mods, so that now these are more robust ?
I recall plastic veins were superseded with metal, but that that issues too - or and I am dreaming
Does fitting a new one of these today make the N52 engine more reliable regards sudden overheat and all the nightmares that goes with that .. or not
Regards
There's nothing in the dark that isn't there in the light .... except fear
Smartbear
Post by Smartbear » Wed Jun 13, 2018 7:57 pm
charlie8 wrote: Wed Jun 13, 2018 6:44 pm Hi
Regards
Hi, I think 60k is a bit pessimistic as they seem to reach 70k+ more typically. The plastic/metal veins were an issue with the early mechanical pumps (m54) as far as I’m aware & not the electronic ones (n52)
Even if the design is unchanged you should get ten years or so before it fails and a new replacement is around £200 these days if you avoid the bmw dealer.
e85 3.0si sold
mr.tourette
Post by mr.tourette » Wed Jun 13, 2018 8:53 pm
mine reached 90k and was still fine.. only changed as precautionary preventative maintenance
philbo909
Post by philbo909 » Wed Jun 13, 2018 8:59 pm
As above mine was changed at 100k and ten years. So it's really not that unreliable
Sapphire black z4 coupe 135,000miles young
charlie8
Post by charlie8 » Thu Jun 14, 2018 12:46 pm
Thanks, very interesting
Mine crossed 10 yrs a few months ago, ~80K , so will put in a new one in the Autumn when I will change the coolant anyway
Be nice to know why they fail, sounds like the electrics just give up, but wonder why/how - as a 'mass' issue, I might try the google
ph001
Post by ph001 » Thu Jun 14, 2018 12:51 pm
charlie8 wrote: Thu Jun 14, 2018 12:46 pm Be nice to know why they fail, sounds like the electrics just give up, but wonder why/how - as a 'mass' issue, I might try the google
Unlikely to find anything over and above the investigation I did back in September last year... viewtopic.php?f=2&t=99913
charlie8
Post by charlie8 » Thu Jun 14, 2018 1:33 pm
So you did, looks like a very 'black box' story
Plenty of surveys out there revealing fail mileage, even one on this forum, but all seem inconclusive and a random spread, and as you seem to have found, there is no audit trail on the cause to help guide prevention. Although data suggests the engines are quite robust, not many die following such a sauna
Every car/engine has its weak points I guess and given BMW have never listed a service/warranty amendment to change the pump on mileage/time or fund fail repairs to stop a brand/model rage from owners, it still must be seen by them as rare enough normal wear item. Also why I started the thread originally, there is not an obvious design flaw to instigate a mkII version etc
Makes me wonder if the tornado rad fan ( if you ramp it to max in diag tool, it'll blow the garage apart ) was there for a reason to indeed stop any permanent scars post fail given its a binary fail point, not a mechanical ramp down
ph001
Post by ph001 » Thu Jun 14, 2018 2:12 pm
charlie8 wrote: Thu Jun 14, 2018 1:33 pm Makes me wonder if the tornado rad fan ( if you ramp it to max in diag tool, it'll blow the garage apart ) was there for a reason to indeed stop any permanent scars post fail given its a binary fail point, not a mechanical ramp down
...problem is, it doesn't matter how much air the rad fan pumps through the radiator if the coolant is not circulating.
