DSC warning lights, am I correct?
mjennings23
Post by mjennings23 » Sat Jun 09, 2018 4:16 pm
Amber handbrake and DSC warning lights came on yesterday and were a bit intermittent today.
Code read gives a 5E20 code, which points to a failure on Pressure Sensor 1. No other codes present.
Live parameters of the 2 pressure sensors shows one at 6.8 bar resting and one at -1.5 bar resting, both rise when pedal is pressed as expected.
So, seems number one is faulty! I assume this is a replace part at the lovely cost of £100ish from a dealer?
Lance
Post by Lance » Sat Jun 09, 2018 5:29 pm
mjennings23
Post by mjennings23 » Sat Jun 09, 2018 5:49 pm
Perhaps, they all seem to be rebuilds as all show the ATE casting marks on the metal case (if the photos are to be believed)
It would irritate me no end buying a cheap part and it failing again though! :roll:
MACK
Post by MACK » Sun Jun 10, 2018 2:37 pm
Looks like it's the sensor to me. Not a fan of cheap parts either, but that said the genuine ones are best of a £100 from a dealer so chancing £20 on something that's so easy to whip in and out might be worth it.
Silver 05 3.0i SE
White E89 20i M Sport
mjennings23
Post by mjennings23 » Sun Jun 10, 2018 2:48 pm
Pretty much the same logic as myself there, I generally always use OEM or equal parts. However with such a small part and being easily accessible, I reckon I might take a punt on an eBay part. Shall decide tomorrow, when I get dealer prices with discount
paolo7
Post by paolo7 » Fri Jul 20, 2018 5:47 pm
Hi, did replacing your pressure sensor 1( from ebay) fix your problem?
I also have 2 warning lights on ,both orange 1 triangle and 1 brake light permanently on, with 1 bleep sound whilst pulling away.
paolo7
Post by paolo7 » Sun Sep 09, 2018 11:01 pm
Thanks all, will try replacing a the sensor will keep you updated
paolo7
Post by paolo7 » Sun Feb 03, 2019 12:27 pm
paolo7 wrote: Sun Sep 09, 2018 11:01 pm Thanks all, will try replacing a the sensor will keep you updated
Changed pressure sensor 1 as my scanner suggested, using ebay item under £20 , hey presto all is well.No alarms or dash lights, was an easy install and no need to bleed or top brakes fluid. :)
tomrdy
Post by tomrdy » Fri Feb 08, 2019 11:12 pm
paolo7 wrote: Sun Feb 03, 2019 12:27 pm
Hey Paolo is it simply just a case of unplugging the part and putting the new one in? No fluid leaks out?
I've had this problem very intermittently - it would beep and lights come up with the error in scanner but after I restart the car, it'd be gone for.. months. Might get the parts ready for when it's not so intermittent :P
-SOLD- Nardo grey 2004 Z4 3.0i E85
-SOLD- 2016 Long Beach Blue M2 DCT
-Wishing- Z4MC Interlagos blue... :oops:
___
Australia
paolo7
Post by paolo7 » Wed Feb 20, 2019 6:34 pm
Yes, you just first unplug from the sensor, then very quickly unscrew the pressure sensor using your finger to stop brake fluid escaping.Now install the new unit. Please check out this youtube video
https://www.youtube.com/watch?v=BufLWbbAMGM
Deadpool
Post by Deadpool » Wed Feb 27, 2019 5:16 pm
I had the same problem for a while - Pressure sensor 2 in my case. Swap the connections and test again to make sure they haven't been plugged in the wrong way around otherwise you might be swapping out the wrong sensor.
I opted for the cheap ebay one (£13). Figured if it lasts some time then it will still work out alot cheaper than OEM prices! Covered about 1k miles so far and not any issues.
https://www.ebay.co.uk/itm/OEM-Brake-AB ... 2749.l2649
2.2i Titan Silver | Red E46 Interior| B06 Set | CF Wrapped Interior | Suede Steering Wheel Re-trim | Stubby | Switch Back AE | CF Grills |18" Wolfrace Eurosport Turismo
2.5i Maldives Blue | Z4M Front Bumper
3... :poke:
mjennings23
Post by mjennings23 » Thu Feb 28, 2019 4:40 pm
So, to answer this as I never did...
Bought an ebay replacement, the day after I ordered it the lights went off and have not come back on since. ISTA-D is also now showing the correct values for both the pressure sensors.
Perhaps a bit of contact cleaner was all they needed after all!
