Yellow exclamation mark and yellow dsc
Took the zed for MOT today and it passed with no advisories.
The only thing he mentioned was that he had to cable tie the brake wear sensor and brake line as it was rubbing on one of the struts.
Off I went happy until I’ve gone back out in the car and now got the dreaded yellow dsc and yellow explanation mark dash lights.
IT must be related to what the mot guy has done but does anyone have an idea of what? They’re shut now but I’m guessing it must be something fairly simple to rectify?
Is it a steering wheel and exclamation mark ??dans6490 wrote: ↑Tue May 22, 2018 5:29 pm Took the zed for MOT today and it passed with no advisories.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
No it’s these ones
They came up on mine a few weeks ago. Someone on here recommended to disconnect battery for 20 mins then once reconnected, drive it 100 yards and all cleareddans6490 wrote: ↑Tue May 22, 2018 5:29 pm Took the zed for MOT today and it passed with no advisories.
Thanks....will give this a try. Do you know if it affects driving at all whilst lit?jamesditchy wrote: ↑Tue May 22, 2018 6:10 pmThey came up on mine a few weeks ago. Someone on here recommended to disconnect battery for 20 mins then once reconnected, drive it 100 yards and all cleareddans6490 wrote: ↑Tue May 22, 2018 5:29 pm Took the zed for MOT today and it passed with no advisories.
It didn't with mine. Try the battery disconnect first and see how you get on
Got exactly the same on my Z3 at the mo. I'm still not sure why, code came up as brake switch!! But not convinced.
Z in da Head.
3.0i Z3 sport,sapphire black,3.0i Z4 roadster Sterling grey,auto,Z4 3.0si Coupe Titanium silver,Stubby &B06 Plus some other German beauties!!
- BRC
All you ever wanted to know and more besides: http://dashboardsymbols.com/the-symbols/
Sold a pair of soft top side covers and now retired.
- ph001
Seems a bit of a coincidence but...
Codes are the surefire way but typically:
1) DSC + ABS = ABS pump.
2) DSC + handbrake (in yellow) = pressure sensor
3) DSC + ABS + handbrake (in red) = wheel speed sensor.
4) DSC + ABS + handbrake (in yellow) + tyre pressure = wheel speed sensor.
5) DSC + ABS + handbrake (in yellow) = steering angle sensor fault / ABS pump.
6) DSC permanently on = steering angle sensor calibration issue / yaw sensor / lat accel sensor.
There are other combinations of faulty sensors which can cause similar lights but the above are the common ones.
Thanks for the reply, it’s appreciated. So it would seem to be the pressure sensor. How easy is that to change?ph001 wrote: ↑Tue May 22, 2018 8:52 pm Seems a bit of a coincidence but...
- ph001
You’d be taking a bit of a gamble to conclude that without reading codes but yes, easy to change. Do a search for ‘pressure sensor’.
- ph001
Those are the ones. Anybody local to you can do a quick code scan first? There are other things that can bring on those two lights.
I love this car but I’ve never known such a temperamental thing in my life! I unplugged the battery last night and this morning......hey presto......the lights are out!
If it reappears I will get it scanned but for now at least all seems well??
- ph001
The pressure sensors do start to fail like that. Most of the time just turning the engine off and back on extinguishes them but they always come back on sooner or later. Wouldn't worry about it though, just drive it.
