Steering moaning at me!
- Magicarcher
Occasionally my steering makes a moaning noise when using full lock manures at low speed. It seams to be mostly when it is hot. Any ideas what it can be?
Z4 3.0L 2005. Titan Silver. Audio Upgrade Second Stereo Pioneer X8700DAB, Sony Xplode 4 x 70W Amp, 6.5" Reckhorn Subs in rear cubby, Focal AS165-3 in fronts.
- Jaw
low ps fluid?Magicarcher wrote: ↑Mon May 21, 2018 12:18 pm Occasionally my steering makes a moaning noise when using full lock manures at low speed. It seams to be mostly when it is hot. Any ideas what it can be?
Z4M Roadster - Gone but not forgotten
E92 M3 | 981 Boxster S | Corvette C4 | 996 911 Gemballa |XR8 | Whatever else is lurking in the garage
- MACK
The steering rack may need re-greasing under the bellows. Its quite common for this to be the source of a groaning noise on the E85/6 apparently, although I've not experienced it myself.Magicarcher wrote: ↑Mon May 21, 2018 12:18 pm Occasionally my steering makes a moaning noise when using full lock manures at low speed. It seams to be mostly when it is hot. Any ideas what it can be?
Silver 05 3.0i SE
White E89 20i M Sport
Under the bellows? Don’t suppose you have a pic of where I’m looking as mine does this too.
2005 e85 z4, 2.5
It's electricJaw wrote: ↑Mon May 21, 2018 12:54 pmlow ps fluid?Magicarcher wrote: ↑Mon May 21, 2018 12:18 pm Occasionally my steering makes a moaning noise when using full lock manures at low speed. It seams to be mostly when it is hot. Any ideas what it can be?
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
I stoppped mine by greasing where the steering column meets the rack . You need to get to it under the car.
2005 Z4 3.0 Black, Zhp gear knob.
- Phoenixboy
mine does it occasionally,a picture of exactly where would be useful.
E89 s drive 30i manual/gone
space grey
Carbon interior trim
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
Gone, E85 Ruby Black.
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
- GuidoK
Thats the part of the steering rack that needs to be relubed generously with axle/bearing grease.
This is a very very common problem and fix.
you need to snip the cvboot type clamps (one time use only), get new ones from the dealer or ebay and clamp them in place with cvbootclamp pliers (can be had on ebay for about £7 delivered).
Dont use jubilee type clamps, they dont apply constant pressure
- Phoenixboy
cheers for that:)Phoenixboy wrote: ↑Tue May 22, 2018 10:23 am mine does it occasionally,a picture of exactly where would be useful.
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
space grey
19" Veeman FS 25`s
cruise control
m sport seats
stubby
led halo bulbs
OEM wind deflector
- Magicarcher
Thanks for your excellent photo and explanation. I haven't come across axle/bearing grease (well not since working my 1970 Austin 1300 manyyy years ago). What should I look for?GuidoK wrote: ↑Tue May 22, 2018 10:34 am
ThanksGuidoK wrote: ↑Tue May 22, 2018 10:34 am
2005 e85 z4, 2.5
Quick question; best way to access via diy car ramp or must it be in axle stands?
2005 e85 z4, 2.5
Bumping this as mine has gone from a groan to a clunk when turning the wheel left. I'll get under the car tomorrow but hints are helpful as I'll have to tolerate midday sun when I'm doing it
